Old 29-11-2008, 11:19 PM   #1 (permalink)
Exclamation please tell cheapest 4870 card
Can anyone please tell me which is the cheapest HD 4870 card here in India? I am currently on a budget for 4850 but want to be future proof for atleast 2 years. 4850 won't sustain that much so if I can get a 4870 with a range of 11k to 13k, I will buy it. Any suggestions would be appreciated.
mib2_007 is offline
Old 30-11-2008, 05:37 AM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: please tell cheapest 4870 card
Spend 4-4.5K more
The cheapest 4870 available in here is :
PalitH D 4870 Dual Sonic 512MB DDR5 256Bit Dual Slot Cooler - Rs. 16800
http://www.theitwares.com/gfxcards/gfxcards.htm
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 30-11-2008, 06:29 AM   #3 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
^^Adding 2K more, you get HD4850X2 or HD4850CF.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 30-11-2008, 10:44 AM   #4 (permalink)
Originally Posted by topgear View Post
Spend 4-4.5K more
thats not mu budget. what about 4850? which one is the cheapest here? or have a game bundled?
mib2_007 is offline
Old 30-11-2008, 02:48 PM   #5 (permalink)
The Smaller Bang
for 11 to 13k budget, get a 9800GTX+.
Old 30-11-2008, 04:49 PM   #6 (permalink)
gtx+ fails on enabling anti-aliasing i think, doesn't it?
mib2_007 is offline
Old 30-11-2008, 05:34 PM   #7 (permalink)
damnbadman666
damngoodman999's Avatar
who told u HD 4850 is not future proof , HD 4850 is 10% - 15% less in getting FPS considering HD 4870 sonic .
1) 1 GB HD 4850 will beat the standard HD4870
2) u can add one more HD4850 in crossfire means it outperforms 280GTX
2 X HD 4850 card in Palit cost [9300 X 2 = 18600/-]
Palit HD 4870 sonic = 16800/-
choose ur self?????
damngoodman999 is offline
Old 01-12-2008, 12:44 AM   #8 (permalink)
thats really great but the problem is all of a persons budget!!! damn... why these things are so costly
how about buying an expertvision 4850 card at 8500 and adding a accelero s1 to that??
mib2_007 is offline
Old 01-12-2008, 04:08 AM   #9 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
Post Re: please tell cheapest 4870 card
i think i reply u in other section
Dell 15z + WD 2TB
Dell Studio 1555 + WD 1TB
iPhone 4 32 GB
Samsung Galaxy S2 White
Good Desktop Power Of C2D + 4850
NIGHTMARE is offline
Old 01-12-2008, 04:35 AM   #10 (permalink)
damnbadman666
Buy Palit HD 4850 now & add another one when u r on money right!!!!
Old 01-12-2008, 04:55 AM   #11 (permalink)
The Smaller Bang
No. Why should it ?
Old 01-12-2008, 05:22 AM   #12 (permalink)
No. Why should it ?
nvidia cards are not goood at it
mib2_007 is offline
Old 01-12-2008, 05:25 AM   #13 (permalink)
Fast 'N' Furious
topgear's Avatar
Your budget is 11-13k. Right ?
Then get this :
Palit HD 4850 Sonic 512MB DDR3 for Rs. 11400
topgear is offline
Old 01-12-2008, 02:28 PM   #14 (permalink)
Then get this :
its not a worth 11400 card, good price for it will be 10500, I think I will buy one xpertvision one for 8500 and add accelero s1 to it, that will be really COOL for me and for card too
mib2_007 is offline
Old 01-12-2008, 06:28 PM   #15 (permalink)
damnbadman666
u r right go for it buddy , save ur money enjoy more gaming !!!
Old 02-12-2008, 04:37 AM   #16 (permalink)
The Smaller Bang
See reviews and you will get the real picture.
Edit: what monitor do you use ? 9800GTX+ drops performance (actually, HD48(5/7)0 gains performance with higher resolution, and at HD, the RV770 cards easily beat it.
Old 02-12-2008, 07:40 AM   #17 (permalink)
Violent serenity.
Psychosocial's Avatar
lol
umm... why cant you learn to advice others correctly ?!
@OP
Your best is either a HD4850 or a 9800GTX+ in that budget. Both are good and neck to neck in performance.
If you want more, you have to pay more. Thats the simple rule.
Last edited by Psychosocial; 02-12-2008 at 07:41 AM. Reason: Automerged Doublepost
Psychosocial is offline
Old 02-12-2008, 04:06 PM   #18 (permalink)
The Smaller Bang
As paranj says, HD4850 is your best bet. Its even faster than 9800GTX+ if you go to higher resolutions, above 1680xsomething, with the performance gap closing on touching 1280x1024 and reducing more and more with HD4850 overtaking 980GTX+ at highest resolutions. For a 1440x900 monitor, I recommend HD4850 since the performance will be roughly equal, but HD4850 will be cheaper by 3K, at Rs. 9,500 for Palit Sonic Edition, which has good overclock headroom.
Old 02-12-2008, 04:20 PM   #19 (permalink)
Rs. 9,500 for Palit Sonic Edition, are you serious? whr are thsese prices from? I am buying it NOW!!! I am in delhi
mib2_007 is offline
Old 02-12-2008, 05:31 PM   #20 (permalink)
The Smaller Bang
^^Actually, for retailers, palit ordinary and palit sonic costs the same since the later replaces the former. but to clear palit ordinary stock, sonic was priced higher in India (in usa its below 170$). I just guessed that old stock must have been over by now and perhaps in christmas season sonic will get a price cut. else it should be around Rs. 700 more than 9500.
Old 02-12-2008, 06:48 PM   #21 (permalink)
damnbadman666
@OP
Oh.. his budget is 13K , that means u would buy him a HD4870 for that price.
sonic is not much worth for its value it has only good cooling, standard palit HD 4850 has good cooling too.
Old 02-12-2008, 11:43 PM   #22 (permalink)
Violent serenity.
@OP:-
Well do what damngoodman999 says. He is God.
Old 03-12-2008, 12:27 AM   #23 (permalink)
damnbadman666
@OP:-
hey cool down !! u be god i leave my place cheers
Old 03-12-2008, 12:52 AM   #24 (permalink)
sonic has few advantages also such as better power management system that increases cards life(if it matters to you ) and is also factory overclocked to settings till he point where normal card can go. So it can get a overclock on that too to reach 750 on core and 1150 on memories. Uses better RAM too from samsung too!!!
mib2_007 is offline
Old 03-12-2008, 03:07 PM   #25 (permalink)
Violent serenity.
^^Nah, still damngoodman999 is right... we all are wrong!
Old 03-12-2008, 05:13 PM   #26 (permalink)
why do you keep saying that psycho?
mib2_007 is offline
Old 03-12-2008, 06:18 PM   #27 (permalink)
damnbadman666
Hey i found that , palit HD 4870 sonic is fall in price after 15th Dec / 09 .??
Anyone have any idea about it.
Old 03-12-2008, 11:03 PM   #28 (permalink)
are you sure? then I will surely wait for the fall.... where did you got the news from??
mib2_007 is offline
Old 03-12-2008, 11:12 PM   #29 (permalink)
damnbadman666
hey i am not sure dude , actually in my place palit distributor is there motherboard price and 9600GT price were reduced & also 600/- reduced in HD 4850 , he told the next will be 4870 sonic ???
i can tell surely after a week , after he confirms with the enterprises
Old 04-12-2008, 12:58 AM   #30 (permalink)
whr do you live? is ur distri Tirupati enterprises?
mib2_007 is offline
cheapest dx10 agp 8x card. mandar5 Gamerz 16 20-07-2007 11:30 AM
Which is the cheapest available vista compatiable tv card spitfire Hardware Q&A 1 29-04-2007 06:55 AM
Cheapest card for Vista nishant_nms Hardware Q&A 24 13-09-2006 08:08 AM
cheapest mobile w/ mmc or any other memory card sysrq Mobiles and Tablets 2 14-09-2005 09:46 AM
Which is the cheapest PCI-X graphics card ? mohanty1942 Graphic cards 2 26-01-2005 10:51 AM
