Old 28-11-2008, 05:21 PM   #1 (permalink)
damnbadman666
damngoodman999's Avatar
Smile help with the Selection of Dell monitor ? urgent !!
i have decided to purchase DELL "2208WFP" monitor for 13500/- is it a good value for money can anyone tell ??
because now i am using 19" TFT "VIEWSONIC VX1932WM" i am not sufficient with 19" inch so i am going for 22"inch for DELL , i am using HD 4850 so i need big monitor in an affordable price .
i am using for gaming and HD movies is this DELL 2208 is good value???
Thanks in advance for your replies !!
damngoodman999 is offline
Old 29-11-2008, 10:03 PM   #2 (permalink)
RMN
Default Re: help with the Selection of Dell monitor ? urgent !!
-deleted-
DELL SP2008WFP|Cooler Master Elite 330 Cabinet|MSI P45 NEO-F|Intel Q6600|Palit HD 4850 Sonic|VISTAx64|Cooler Master PCAR-600|Transcend 2GB 800M|Creative SB LIVE!Ext.|Logitech Combo EX-90
RMN is offline
Old 30-11-2008, 01:47 AM   #3 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
hey hey hey.. wat was tat reply all about ?? haan ??? u better be calm buddy else stop posting here if u jus cant help and care to reply to questions...... simple and straight as this.....
Btw,, to the OP (original poster)
buddy, DELL's a good option but yes ppl will also suggest u to jus hv a look at the Samsung brand as well..(i will also suggest u the same thing)...
But, yes the choice u made is good value for money, so u can go ahead with the purchase..coz as u mentioned u hv a HD 4850.. so a DELL LCD will hv abit more functionalities as compared to a Samsung one.. so go with DELL ..
Cheers n e-peace...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is online now
Old 30-11-2008, 02:24 AM   #4 (permalink)
damnbadman666
thank you for your advice
Old 30-11-2008, 09:21 AM   #5 (permalink)
RMN
@ashu
dude....my reply was to a spam posted by some idiot... ...its gone now anyway.
@damngood
i have SP2008WFP(i guess its the older model) and im satisfied with it....anyway just check for dead pixels before you buy it...
RMN is offline
Old 30-11-2008, 03:00 PM   #6 (permalink)
damnbadman666
Originally Posted by RMN View Post
@ashu
@damngood
But it Dell is the best monitor to choose after SAMSUNG right , in 22"inch 2ms response time , this the monitor available in INDIA what to do??
Old 30-11-2008, 03:37 PM   #7 (permalink)
RMN
i guess if you add 1k more you will get Full HD monitors.
RMN is offline
Old 01-12-2008, 01:25 AM   #8 (permalink)
RMN wrote:
@ashu
Ooh is it ?? well extremely sorry then for my stupid comment...
Cheers n e-peace...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
where to buy dell monitor in kerala george101 Hardware Q&A 3 27-11-2008 01:46 PM
where can I buy Dell Monitor in Delhi ravi_9793 Hardware Q&A 5 08-10-2008 12:22 AM
Dell Monitor bal1961 Hardware Q&A 4 28-04-2008 03:43 AM
Best Viewsonic/Dell Monitor psmontte Hardware Q&A 1 28-02-2008 04:13 PM
