Old 27-11-2008, 11:00 AM   #1 (permalink)
Kalyan's Avatar
Default PC not responding. Need help..
Hi, my pc has slowed down and giving me errors now and then. My Sony DVD RW does not read dual layer disks and cds properly. I have a 400W stock PSU. and my configuration is in the sig. Is the power supply the culprit? Do I need to upgrade the PSU or can I run the setup with it? Recently reading some of the drives on the hard disk is taking too long, both in XP and Vista.
At times, it is taking ages on the loading screen.
Thanks in advance
My config: AMD Athlon x2 5600+, Asus M2NPV-VM, Transcend 2x1GB 800MHz, XFX 8600GT 256MB, Seagate 250GB SATA2 + Seagate 500GB SATA2, LG 1752s LCD, Sony DRU v200A DVDRW, Logitech MX518, iBall Benz cab
Kalyan is offline
Old 27-11-2008, 11:13 AM   #2 (permalink)
Violent serenity.
Psychosocial's Avatar
Default Re: PC not responding. Need help..
It can be a problem with your HDD and DVD-RW rather than PSU...
Psychosocial is offline
Old 27-11-2008, 11:15 AM   #3 (permalink)
Kalyan's Avatar
The HDD is new one. but ya.. the dvdrw came from the service center. and it is malfunctioning. Can I be sure that the stock PSU is able to power my pc?
Kalyan is offline
Old 28-11-2008, 07:48 PM   #4 (permalink)
u can check ur psu by a multimeter. But i think it can be virus or corrupted window files ....... may be u ned to reinstall ur os but it can be better if u take a screenshort of errors and post it here........
dixit8611 is offline
cd rom not responding sanyaldk Hardware Q&A 1 25-08-2008 01:36 AM
USB PORT NOT responding avidasioc Hardware Q&A 4 24-10-2007 10:30 PM
not Responding JohnephSi Mobiles and Tablets 1 19-06-2007 01:50 PM
DVD ROM not responding ritish Hardware Q&A 3 20-05-2007 11:06 AM
DVD not responding coolsunny QnA (read only) 5 17-08-2006 01:57 PM
