Old 26-11-2008, 09:10 PM   #1 (permalink)
Arun the Gr8's Avatar
Question Samsung DVD Writer causing high CPU usage. Help!
Hey guys,
I have a Samsung SH-S203B SATA DVD Writer and since the last 3 DVDs i burned it is causing nero to show high CPU usage. The mouse cursor moves very slowly (like when i am getting low frame rate in crysis).
Also since i connected this writer my PC's boot-time has increased. It takes like 10 secs to detect the dvd writer during boot time.
Before this happened, the dvd writer took like 30 secs to detect a blank DVD (but readily detected blank CD and burned discs). Now it takes like 4 secs. In nero it took 10 secs after i pressed next after selecting the files. Now it happens instantly. It took almost 1:30 mins to start my DVD to burn after i pressed Burn. Now even that happens instantly.
But after that things become real slow. It takes more than an hour to burn a DVD at 8x. Even the estimated time shows almost 50 mins.
Same problem happened before. But then i was able to burn using K3b in ubuntu with ease so there was no problem. but now i dont have ubuntu. so i cant tell u guys how its working in ubuntu..
Is it because i am using SATA interface. Help. Plz...
New Dell Inspiron 14: Intel Core i3 350 - 2.26 GHz, 2 GB DDR3 1066 MHz RAM, 320 GB 7200 RPM HDD, 512 MB ATI Mobility Radeon HD 4330
Arun the Gr8 is offline
Old 26-11-2008, 09:33 PM   #2 (permalink)
Ethan_Hunt's Avatar
Default Re: Samsung DVD Writer causing high CPU usage. Help!
Check if the drive has gone into PIO mode from Device manager. If it has then reset it to Ultra DMA mode.
V for Vendetta
Ethan_Hunt is offline
Old 27-11-2008, 01:02 AM   #3 (permalink)
I couldnt find any pio mode in Device manager. Can you specify the location plz...
Found PIO mode.. Will try burning again.. Wil tell ya if it works..
Thanks..
Last edited by Arun the Gr8; 27-11-2008 at 01:06 AM. Reason: Automerged Doublepost
Unusually high CPU Usage ashu_dps Hardware Q&A 4 13-11-2007 08:50 PM
High page-file usage? reason? jack_the_ripper QnA (read only) 7 17-09-2007 06:13 PM
Abnormally High Broadband Usage Soumyajit Broadband and DTH 11 07-07-2007 10:39 PM
High CPU usage while copying DVD/CD blackpearl Software Q&A 17 01-07-2007 10:54 PM
