Old 26-11-2008, 08:03 PM   #1 (permalink)
Default frontech tv tuner problem
guys i need help,
i recently bought frontech jil-0606 internel tvtuner card, i did what the manual said, i installed the driver and software. It was succesful in few attempts. Now i have few problems:
1.Remote is not working
2.No sound
3.got ohnly few channel..doordarshan ones and one or two more
so what shud i do ? ne solution
plz helpppppp !
gfxdev is offline
Old 27-11-2008, 12:09 AM   #2 (permalink)
Point Blanc
Default Re: frontech tv tuner problem
wont help then
uninstall and re-install.
If goes well then good otherwise, you will need a new from other company.
Get it changed from the shop you took it
acewin is offline
FRONTECH tv tuner card - stuck lost - urgent help needed sincereheart QnA (read only) 8 27-08-2008 01:37 PM
Vista and Frontech tv tuner card eureca_eureca Software Q&A 4 02-10-2007 11:58 AM
Frontech T.V Tuner Card pirates1323 QnA (read only) 2 12-03-2005 12:38 PM
