25-11-2008, 06:29 PM
run computer without earthing
hi i am planning to bring my computer to my hostel but my hostel pluck dont have earthing is it very dangerous to rus computer without earthing or is there any way to provide earth to it .. i cannot open plug or boards as it is illigal in hostel any temporary measure precaution will help
Intel core 2 duo e4300 1.8 ghz 2 ddr2 ram
945 gl mob xfx gforce 8600 gt 512 mb 200gb hdd
25-11-2008, 06:42 PM
15.0 GHz
Re: run computer without earthing
I am using my PC without earthing.....i got my new PC in Nov 07 till now nothin happened ...but u should make earthing....i am planning 2 do it in near future.
25-11-2008, 10:14 PM
King of my own Castle
Normally it should matter much,though an earthing helps.Still this is what you can do !
Take a normal electrical wire and attach one end on the wire to the back cabinet nut.And the other end thrust it in a wall with nail or whatever you seem fit.
This is not a perfect earthing but will serve the temp purpose.
26-11-2008, 12:01 AM
Earthing does matter a lot.. With insufficient or improper or no earthing, there is a high chance that your computer's internals will get damaged.. especially stuff like the HDD.. Get an earthing done immediately or at the earliest. Not sure of any other alternative solutions.
26-11-2008, 09:04 AM
yeah i suggest you should get earthing.....
and make sure when you are not using your system you cables are disconnected from the socket.
DELL SP2008WFP|Cooler Master Elite 330 Cabinet|MSI P45 NEO-F|Intel Q6600|Palit HD 4850 Sonic|VISTAx64|Cooler Master PCAR-600|Transcend 2GB 800M|Creative SB LIVE!Ext.|Logitech Combo EX-90
26-11-2008, 04:28 PM
Relatively better and safer option is to put the other end of wire in a flower pot (And keep the soil in the flower pot moistened)
27-11-2008, 02:27 AM
Wire muncher!
ZOMG ZOMG ZOMG... Don't ever believe all those who say "Earthing is not necessary"!! It is absolutely a must, for your PC's good and yours too.
Any leakage current will slowly but surely kill the electronics. Also there is a chance of you contracting an electrical shock (whatever magnitude it is). Do ensure that you get proper earthing done before you get your computer. If won't cost must if you wanna get it yourself.
27-11-2008, 03:13 AM
ANGEL OF DEATH
earthing is very necessary for PC its like slow poison but some its happen very fast i faced lot of problem due to earthing.so i suggested u plz don't run ur pc without earth.
| Dell 15z + WD 2TB | | Dell Studio 1555 + WD 1TB | | iPhone 4 32 GB | | Samsung Galaxy S2 White | | Good Desktop Power Of C2D + 4850 |
28-11-2008, 11:40 PM
Project Halcyon V2.0
NEVER EVER DO IT, you'll get a fried PC in no time, trust me, I learned it the hard way(cost me 4k + lifetime of collected DATA when my HDD went kaput)
Project Halcyon v2.0:
12-03-2010, 05:16 PM
Old post but found it via search i am having some major problem with my new speakers & it seems due to earthing problems.
I hear a hissssssssssss sound from newly bought creative speakers T3030 which does not go & the volume has to be manually controlled down, they are picking up the sound of cabinet fans & mouse moments over the files (all window sounds are OFF) Hdd acessing is also sounding through speakers I suspected earthing problem creating this hisssss sound so I got the whole wiring checked.
The mains have earthing, all points have earthing, the ups was checked for earthing, the smps was checked for earthing & all have the correct earthing but this hiss sound does not go away, the electrician checked by using a bulb holder & putting wires in phase+earth & the bulb illuminated indicating that the earth is proper grounded.
Can anyone find another source of problem either with computer earthing or speakers?
15-03-2010, 09:31 AM
Wire muncher!
Bad audio cable/connector maybe?
15-03-2010, 10:07 AM
Both are provided by creative with gold pins, in further testing
I connected my main desktop to these speakers (earlier these were connected to my old computer) keeping everything same, the hissing sound is gone completely, the main computer has branded SMPS zebronics platinum & also the sound card was different, my main doubt is now on old unbranded 400watt smps, cant fit the new smps in that old cabinet since its small old cabinet, will test later with the new smps & report back.
Speakers are now perfectly fine & I played upto 80% volume without a hint of hissing on the testing computer.
Any clue what else could be wrong , some kind of shielding required or insulation which may improve, when i connect the tv tuner with old set up i get a interference signal too see attached image which does indicate that there is some signal interference happening from the CPU/smps or some other source.
I need help to figure this out.
15-03-2010, 10:21 AM
Super Moderator
To check if there is any leakage, take a line tester, touch it on the computer metal. If it glows, you have an electrical leak. Get earthing.
15-03-2010, 11:21 AM
Read my earlier post earthing was tested 2 different way, with the line tester 1 wire in phase + another on the back of computer body is that what you want to test?
15-03-2010, 12:13 PM
Super Moderator
Oh okay. Missed that post. Even my speakers hiss, but I have local crap ones. Its highly probable, that there is some interference between the sound card and PSU. Are they close by.
15-03-2010, 12:19 PM
No not really close, just normal separation of 7-8 inches, its not the distance but some kind of electromagnetic interference which is causing this, cant figure out a method to pin point it.
Update
just saw the cabinet back the smps is mounted vertically so the distance is exactly 3 inches between the 2 of them, could that be the problem?
16-03-2010, 08:29 PM
Hosting Specialist
How far is your UPS from the old pc? If it is too near, try having it atleast around 3 feet away.
►ExpertWebHost.NET- Quality, budget web hosting service since 2008
16-03-2010, 11:05 PM
Super Moderator
Do the above mentioned. If it does not work then try this:
Place a thin thermocol sheet on both sides on the sound cards. You could use rubber bands to bind them. This should kill and interference, which 'could' be causing the backfeed hiss...!
