Old 25-11-2008, 07:48 AM   #1 (permalink)
Smile Help me !!! Hard disk
I am having mobo D102GGC2 with 1GB RAM and 80GB ATA Harddisk with Sony DVD writer(So called ata or scsi).The reason to post all these here is that i want to add 500GB SATA Harddisk to my computer, so it is possible to use both harddisk ATA and SATA at the same time and my dvd writer will work or not. Please tell me D102GGC2 supports max of how much GB of Harddisk, can i also add 1TB HD.
Relpy SOon...
prateek007ster is offline
Old 25-11-2008, 08:52 AM   #2 (permalink)
slugger's Avatar
Default Re: Help me !!! Hard disk
max HDD capacity is restricted by BIOS version..not the mobo itself
ur mobo shud support 1TB SATA even w/o BIOS flashing
buy a 1TB HDD...will face no issues
slugger is offline
Old 25-11-2008, 04:18 PM   #3 (permalink)
Smile Re: Help me !!! Hard disk
can i use both sata and ata at the same time.
Old 25-11-2008, 04:21 PM   #4 (permalink)
Democracy is a myth
rhitwick's Avatar
If ur MOBO supports SATA u can use both IDE and SATA.
And the IDE cables accepts two connections at a time, as u've told ur DVD writer is ATA, make it as slave and IDE HDD as master and primary boot disk (if planning to boot from this hdd).
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now
Old 25-11-2008, 04:27 PM   #5 (permalink)
which HDD IDE or SATA.
Is there any limitation on the size of HDD??
Can i use 1TB HDD how much it costs...If u know any brand plz tell me with its street price(Cheapest-Costliest)....
Old 25-11-2008, 04:33 PM   #6 (permalink)
Democracy is a myth
rhitwick's Avatar
Thumbs up Re: Help me !!! Hard disk
Abe, IDE cable IDE device-hi support karega na...and as per ur info ur old HDD and DVD-Writer both are ATA, so connect them as I told.
As our experts already told, u won't face any problem using 1TB.
Yes u can. In brands I would mention Seagate, Hitachi and WesterDigital.
For prices check here.
http://www.theitwares.com/
Old 25-11-2008, 04:44 PM   #7 (permalink)
Heartly thanks to u all for helping me...
Hard thinking about Hard Disk power_8383 QnA (read only) 10 25-03-2008 05:14 PM
all files from IDE hard disk with windows 2000 to SATA II hard disk with windows jagadish2005 Software Q&A 8 10-04-2007 11:08 AM
RAM and Hard Disk george101 Hardware Q&A 9 24-12-2005 11:24 AM
compaq deskpro ep/sb series not detecting hard disk disk aditya169 QnA (read only) 3 22-05-2005 07:14 PM
80GB hard disk converted into 10780 MB hard disk ssingha QnA (read only) 12 24-08-2004 11:57 AM
