Old 24-11-2008, 07:06 PM   #1 (permalink)
Indidiot
Plasma_Snake's Avatar
Unhappy UPS Backup reduced???
As most of the forum members know, I recently bought a APC Smart 1KVA UPS. I had been using it for keeping my system up and running while the power's gone and that meant usually an hour but in worst cases maybe 2 hrs on full charge BUT the important thing is that it kept running without any hitch.
For past one week I've noticed that now even after a full charge, backup time has been reduced to just 40 mins. What happened?? As the Joker says in The Dark Knight "Did his balls just drop off???" There have been no new hardware additions and even the low and critical battery level for it has been set to 5% and 1% respectively by me. What's going on, I mean is this reduction natural or a foul play?
Plasma_Snake is offline
Old 24-11-2008, 11:48 PM   #2 (permalink)
Default Re: UPS Backup reduced???
Isn't it in warranty? Let APC deal with the headache. Ask them to replace the batt!
How many times have you charged/discharged it? Batts have a specific life-span; in that they can be charged a specific no. of times. After that you need a new one!
Raccoon is offline
Old 25-11-2008, 12:20 AM   #3 (permalink)
Indidiot
Well I'm trying to get online help from APC guys and see what happens. I bought from Delhi and going there and chugging the 20Kg behemoth along is not an easy task. It has charged and discharged numerous times, almost on daily basis but I bought it in this October only, it shouldn't die down so soon.
Old 25-11-2008, 01:16 AM   #4 (permalink)
If its so new, it sure should not behave that way. Hope you get it replaced from APC.
Raccoon is offline
Old 25-11-2008, 02:26 AM   #5 (permalink)
Wise Old Mouse
mrintech's Avatar
Go replace it
- MrinTech :)
mrintech is offline
Old 25-11-2008, 08:07 AM   #6 (permalink)
Section Moderator
gopi_vbboy's Avatar
Replace the BATtery MAN
gopi_vbboy is offline
Old 25-11-2008, 10:15 PM   #7 (permalink)
Indidiot
I mailed APC but no reply yet, queried Contec System's through npithub.com but no reply from there either. Thinking of calling the vendor but wanna know one thing, what should I say I want to claim the warranty on the basis of? $hitty cheap batteries or what? :S
Old 25-11-2008, 11:06 PM   #8 (permalink)
Try their toll free customer care number. Tell them your back up time has reduced (as you said)... and that you feel you have been given a defective battery...
Raccoon is offline
Prices of Dell reduced Cerebral Assasin Technology News 19 04-01-2008 01:25 PM
XBOX 360 PRO price reduced to Rs.15,380 in India ruud_tarun Gamerz 2 16-12-2007 06:06 PM
1GB pendrive reduced to 120MB on its own plz help me seriously ANURAG SHARMA QnA (read only) 31 21-08-2007 09:16 PM
Bharti declared to REDUCED... Stick Mobiles and Tablets 24 17-02-2007 01:07 PM
Monitor size reduced.... ionicsachin QnA (read only) 11 24-05-2006 05:46 PM
