Old 22-11-2008, 01:43 PM   #1 (permalink)
Default Bsnl modem LAN port is not working. What next?
Hello
I have a bsnl-provided modem (Sterlite SmartAX MT882) whose Lan port is not working. When i use it to connect it to the computer, it says Limited or no coonectivity (The modem works fine when connected with the Usb port)
I now need the lan port to connect it to an external device (net phone) that uses Lan ports only.
So should i replace the modem or can it be repaired? Are there any optons to connect the Usb port to the external Lan port ?
Thank u & Have a nice day,
Hemanth
hdavuluri is offline
Old 22-11-2008, 11:12 PM   #2 (permalink)
Project Halcyon V2.0
tkin's Avatar
Default Re: Bsnl modem LAN port is not working. What next?
Originally Posted by hdavuluri View Post
Hello
Hemanth
Your modem is absolutely fine, the problem is that its max supported speed is a lot less than your LAN speed(10/100/1000 LAN ports are dreadfully fast) but your net connection can't occupy even 1% of those speeds, so you can utilise net no problem.
Actually no net connection(hence modem) is as fast as today's LAN ports, they are designed for PC to PC connectivity and file sharing, right click LAN icon, click Properties, uncheck the box notifying you about low connectivity to get rid of the message, you can use net fine.
Project Halcyon v2.0:
[i7 2600k|Asus Z68 VPro|Vengeance 2x4GB|MSI GTX580 Lightning]
[TX 750v2|Seagate 500GB+WD Cav Black 1TB|CM HAF 912 Adv]
[Logitech G110|G500|Adata/750GB+WD/500GB USB 3.0]
[APC 1100VA|XBox 360 Controller|Noctua U12PSE2]
[Siberia Soundcard(Xear 3D)|Koss Portapro|FiiO E6]
[Audio Technica M35|PL30/EOL'ed]
tkin is offline
Tutorial: Port Forwarding in ZTE ZXDSL 831AII Modem 100% working! jal_desai Tutorials 13 13-06-2009 05:12 PM
BSNL modem 'forgets' port forwarding after it is restarted *GandaBerunda* Hardware Q&A 3 04-11-2008 01:18 PM
Does ur BSNL DataOne modem(type I) has USB port? shrohit Networking 5 13-09-2005 11:58 PM
