Old 21-11-2008, 06:27 PM   #1 (permalink)
Red face How To Use Dm
HELLO CAN ANYBODY TELL HOW TO FORMAT THE HDD USING DM ONLY NOT ABOUT WIN98 CD OR XP CD. BECAUSE MY C DRIVE IS NTFS PARTITION AND I WANT TO FORMAT WITH DM DISK ONLY PLZ ANYBODY CAN HELP ME
tHANKING U
HIDAYATH
hidayath7 is offline
Old 21-11-2008, 06:32 PM   #2 (permalink)
Democracy is a myth
rhitwick's Avatar
Default Re: How To Use Dm
What is DM?
Do you want to format 'C' drive while staying on OS?
Is your OS installed on 'C' drive?
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now
Old 21-11-2008, 07:48 PM   #3 (permalink)
toofan's Avatar
DM is disk manager.
Check my work at:
http://www.flickr.com/photos/vimaljoshi
toofan is offline
Old 22-11-2008, 02:00 PM   #4 (permalink)
[ya it is in a c drive and i want to format it with disk managment(DM) AM GETTING DEAD BLUE SCREEN SO I WANT TO FORMAT I CANT REPAIR IT ALSO WHEN IT GOES TO REPAIR OPTION IT GET BLUE SCREEN
Old 24-11-2008, 04:55 PM   #5 (permalink)
I suppose you want to format c: from OS. If yes stop doing it. Can you rip your heart off when you are alive?
Tell us why you want to format C: (from OS) and why only DM?
dvijaydev46 is offline
Old 26-11-2008, 08:12 PM   #6 (permalink)
am getting blue screen error and i want to format and i want clean install the winxp i cant format from win98 bcoz it is in ntfs so i want to format with dm cd only if u have any other option to format plz tell me ok bye
