21-11-2008, 02:34 PM
Is this OK ?
probably I am going to buy this rig next week ..............it will be primarily for moderate gaming, surfing, watching movie etc. (no overclocking for the time being......will try later)
- Processor : Intel E5200 : 4500
- Mobo : (Please suggest one within 4500/-) : 4500
- RAM : Kingston 2 X 1 GB DDR2 800 Mhz :1800
- HDD : Seagate 500 GB SATA II (16 MB buffer) : 3200
- Optical : LG GSA H55N : 1050
drive
- Cabinate : Zebronics Bijli :1000
- SMPS : Cooler Master Extreme 500 Watt :2500
- Keyboard: Logitech Keyboard & mouse (optical) :1000
- GFX card : EVGA 9600 GT KO :7500
- Speakers : Altec Lancing BXR 1121 : 1300
TOTAL : 28350/-
is this OK for the price ? any other suggestion ? ......please help.....thnx.
21-11-2008, 03:43 PM
Re: Is this OK ?
Processor :E7200 for 5900.00 ( the performance hike you will get will be worth the money spent.)
Motherboard: MSI P35 NEO-F for 4600.00
Abits IP35-E for 5600.00
Speakers: creative SBS 370 for 1300.00
Rest is ok.
If you want some good gaming then go for Palits HD 4850 for 9500.00 other wise that is ok.
21-11-2008, 04:22 PM
Re: Is this OK ?
Good but go for little extra.
Processor: intel core 2 duo E7200
Speakers: Creative Inspire 3100(Little costs extra)
Or
Creative Inspire 2600
21-11-2008, 04:44 PM
Re: Is this OK ?
thnx all........which will be better MSI P35 NEO-F OR MSI P43 NEO-F
and now confused about the speakers
21-11-2008, 06:02 PM
Violent serenity.
Re: Is this OK ?
E7200
ASUS P5K PLVM
1x2GB DDR2 667MHz RAM
250gb Seagate Drive
Zebronics Bijli cabinet
CM EP 500W
eVGA 9600GT KO
Altec Lansing BXR1121 2.1 speakers
Logitech Multimedia Desktop kbd/mouse
Rest is ok.
Both are old and EOL mobos. Think before blindly recommanding them. P45 Neo-F retails for hardly 1-1.2k more and is definitely worth to go for it.
Reason: Automerged Doublepost
21-11-2008, 07:54 PM
Re: Is this OK ?
Do we know about his budget. so these are somewhat similar to what he posted about 4500/- for mobo.
and this mobo is frequently suggested by many members and even the Agent 001 in the digit mag.
21-11-2008, 08:40 PM
Violent serenity.
Re: Is this OK ?
^^It WAS suggested. No more.
21-11-2008, 09:21 PM
Re: Is this OK ?
For your usage ... i wld recommend the following changes..
Processor : Intel E5200 : 4500 --> E7200 : 5600 (+ 1100)
Mobo : For moderate Overclocking Gigabyte G31 : 2700 ( - 1800)
HDD : Seagate 500 GB SATA II (16 MB buffer) : 3200 --> WD 640 GB 16MB : 3800 (+600)
drive
So your total budget will remain the same and u'll get better performance. But if u can extend your budget a little more then i will say Get Palit 9800 GT for Rs.8200, u'll nt regret. Its wayy better than 9600 GT and will be more future proof with upcoming Shader Intensive games.
Wats the Favourite Mathematical Function of DIGIT FORUM ????
Its "A SINE WAVE" constant
Y ??
They Both keep going "UP AND DOWN, UP AND DOWN............" !!!!!!!!
21-11-2008, 09:30 PM
EXIT: DATA Junkyard
Re: Is this OK ?
But one thing, if u can anyway get E5200 for Rs.4000 in anyway, don't leave it, it's worth it. Especially once u OC it to 3.4GHz.
G31 will allow that much.
9600GT cost about 6.5k
Get AltecLansing ATP3 2.1 @ 2.4k(speakers, awesome)
For 9600GT, u can get CM460W @ 2.2k and save.
21-11-2008, 10:21 PM
Re: Is this OK ?
^ATP3 has been discontinued long time ago. It has been replaced by VS2421.
And in my opinion 9800 GT >>>> 9600 GT (112 shaders Vs 64 ) ..and it will perform way better in shader intensive games.
And to OC 5200 to 3.4 Ghz ... u need a very very good cooler ...... so E7200 is better for him coz he is not thinking of OCing in near future.
Y ??
21-11-2008, 10:31 PM
EXIT: DATA Junkyard
Re: Is this OK ?
No, 4GHz on AIR has been done.
But I suggest 3.4Ghz wich will indeed be easy with that PROCC>
Yes again, but frm wat I've seen, 9600GT is more VFM, and MORE OC. But 9800GT is a gud option too.
If 9600GT, he can save again on PSU, and CM500W is about 2.7-2.8k, 0.5k more.
21-11-2008, 10:47 PM
Re: Is this OK ?
the OP is looking EVGA 9600 GT KO which is the best 9600 GT out there and its 7.5k ... PAlit 9800 GT is 8.2 k and is worth the price difference. After All Stream Processor Do count a lot in graphically heavy games and difference of (112-64) 48 SP's is Significant.
And about 5200, i agree its a really good proccy for its range. It will be a good choice and and will make 9800 GT in the budget too.
Y ??
22-11-2008, 08:41 AM
Re: Is this OK ?
drive
Go for this one its better. But for speakers look for creative one in lower range.
And if you can extend you budget a bit I will recomend you the Palit's HD4850 for 9500.
