Old 20-11-2008, 08:58 PM   #1 (permalink)
Default System crashes
Whenever I play a game(mostly in farcry 2), the system hangs for about 5 sec. it is followed by blue screen(somthing is written on it).
I use Cooler master 600w PSU.Vista 32 bit.It never happened on XP.
Do the power chord we get with PSU matters ?I'm using old power chord
What could be the problem ?
redmanc is offline
Old 20-11-2008, 11:59 PM   #2 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Exclamation Re: System crashes
Post the details on that blue screen appearing on your screen. For your information, that blue screen is called BSOD aka Blue Screen of Death, an infamous lock-up of windows when some serious problem happens to a PC.
I think this problem is because of using outdated Graphics Card drivers. What Graphic Card do you have? Please download and install the most recent driver installer from card manufacturer's original website and then try again to play the game.
debsuvra is offline
Old 21-11-2008, 12:46 AM   #3 (permalink)
Default Re: System crashes
Something dumping physical memory is written on the bottom of the blue screen, when it reaches 100mb the PC restarts.Its hard to read the rest
Well, I'm using Palit HD4850 Graphics card and I'm on the latest Drivers. It even used to happen with old Drivers(the one which we get from the CD.)
I'm downloading Vista service pack 1 as we speak.
redmanc is offline
Old 21-11-2008, 12:54 AM   #4 (permalink)
well if the system used to work fine on xp that probabaly mean there is something buggy in vista ....it could be driver of ur audio video ,or os itself or mybe the game to ....update and patch everything
allmighty is offline
Old 21-11-2008, 10:20 AM   #5 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
The actual BSOD message is very important for troubleshooting and if you can't manage to read it, take a pic and post it here (don't attach it to this thread, instead use a image uploader like imageshack). BTW Windows SP1 is most recommended before trying anything else, install it and check if the problem persists.
debsuvra is offline
Old 21-11-2008, 01:15 PM   #6 (permalink)
JojoTheDragon's Avatar
blue happens mostly for faulty ram. Clean your ram slots and insert again. Or try with different ram modules.
| Steam: jojothedragon | Origin : jojothedragon | PSN : jojothedragon |
TDF @ Steam
Get 2GB of free cloud space : http://db.tt/OJKPcZnY
JojoTheDragon is offline
Old 21-11-2008, 08:34 PM   #7 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Lightbulb Re: System crashes
BSOD is not something related only with faulty RAM modules, it mostly happens due to hardware problems and faulty drivers. So what we definitely need is a good look at the BSOD error report to check the actual problem.
debsuvra is offline
Old 22-11-2008, 12:06 AM   #8 (permalink)
It happened again couldn't read anything. changed the ram slots.
redmanc is offline
Old 22-11-2008, 08:11 AM   #9 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Do you have a Digital Camera or something like that, even a 2MP cellphone camera will suffice. Grab a pic of the BSOD and post here, if it's too fast for you to read.
debsuvra is offline
Old 23-11-2008, 02:05 AM   #10 (permalink)
If it happens time and time again will it cause any damage to my hardware ?
redmanc is offline
Old 23-11-2008, 12:37 PM   #11 (permalink)
RMN
@red
does "atiKmdag.sys" appear on the BSOD?
DELL SP2008WFP|Cooler Master Elite 330 Cabinet|MSI P45 NEO-F|Intel Q6600|Palit HD 4850 Sonic|VISTAx64|Cooler Master PCAR-600|Transcend 2GB 800M|Creative SB LIVE!Ext.|Logitech Combo EX-90
RMN is offline
Old 23-11-2008, 04:20 PM   #12 (permalink)
Originally Posted by RMN View Post
@red
what does aitkmdag.sys mean ?
Managed to get a pic-
it is atiKmdag.sys
now what ????
redmanc is offline
Old 24-11-2008, 08:35 AM   #13 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
^^^ What a 'EYE watering' picture, brings BSOD to eyes.
BTW your error regarding atikmdag.sys in related to faulty driver from Ati. I guess you are using latest 8.11 drivers and still this problem is not resolved. This is a known problem with Ati cards and Windows Vista and yet to be fixed officially. Somebody mentioned in the web that renaming that atikmdag.sys to anything else (like atikmdag.doc) should stop this problem. Try that.
@red
Well RMN, you suspected right.
debsuvra is offline
Old 24-11-2008, 10:17 PM   #14 (permalink)
RMN
@red
try this out.
i too own a Palit HD4850 sonic along with a Cooler Master PCAR-600.
i had a problem where i use to get red patches and green dots which led to this same BSOD.
turned out that the power converter i got with my GFX card was faulty.i just flexed and bend it and now its fine...i finished COD4!
but before that try cleaning your drivers and re install it as debsuvra suggested.
best of luck
RMN is offline
SimCity 4 crashes and restarts system!! hearthacker Gamerz 2 28-03-2007 11:02 PM
What to do if a system component crashes? unni Open Source 4 16-03-2007 11:50 PM
system crashes jojoji_jojo QnA (read only) 4 04-02-2006 08:15 AM
PAGE_FAULT_IN_NONPAGED_AREA system crashes Aanand QnA (read only) 9 22-09-2005 01:30 AM
System Crashes Unexpectedly - URGENT HELP REQUIRED naveen_nic Software Q&A 3 09-05-2005 01:40 PM
