Old 20-11-2008, 03:39 PM   #1 (permalink)
Project Halcyon V2.0
tkin's Avatar
Default Help:Seagate 500GB 32MB HDD Dead
I need urgent help, my 1.5 month old 500GB Seagate 32MB Buffer HDD just died on me.
Last night the drive became slow, took 15mins to copy 5GB data, after I rebooted my system the drive is no longer recognized by the bios, it still spins up and HDD lead kept blinking.
The same thing happened to me 3yrs back with a 160GB Seagate HDD that died after 2 months, got it replaced and its running fine till today.
So, should I RMA the drive and keep using it or switch to Western Digital?
-----------------------Thanks in advance.
Project Halcyon v2.0:
[i7 2600k|Asus Z68 VPro|Vengeance 2x4GB|MSI GTX580 Lightning]
[TX 750v2|Seagate 500GB+WD Cav Black 1TB|CM HAF 912 Adv]
[Logitech G110|G500|Adata/750GB+WD/500GB USB 3.0]
[APC 1100VA|XBox 360 Controller|Noctua U12PSE2]
[Siberia Soundcard(Xear 3D)|Koss Portapro|FiiO E6]
[Audio Technica M35|PL30/EOL'ed]
tkin is offline
Old 20-11-2008, 04:06 PM   #2 (permalink)
Default Re: Help:Seagate 500GB 32MB HDD Dead
if it is under warranty then get a replacement..and then sell it if you want after that
realdan is offline
Old 21-11-2008, 05:40 PM   #3 (permalink)
Point Blanc
well it would be under warranty 7200.11 series is new and he already said it is 1.5 months old.
Why are you hasseled tkin, give it for replacement.
the HDD is good, so I do not think you should give much thought not necessity to switch to WD, get it replaced,
acewin is offline
Old 21-11-2008, 05:58 PM   #4 (permalink)
Violent serenity.
Psychosocial's Avatar
Seagate is good. I am using the same drive as yours . Send it for RMA.
Psychosocial is offline
Old 22-11-2008, 10:10 PM   #5 (permalink)
tkin's Avatar
Thanks for the support, think Seagate deserves another chance, I still trust them because my older replaced drive(250GB) still running fine even after all the tortures I inflicted on it. 7200.11 is the latest model, may be it needs some improvements(firmware upgrades).
Some websites wrote that a firmware module might have become corrupt due to another faulty firmware module controlling the head, the issue is resolved in later models and Seagate will get me a new one with updated firmware. Hope this one lasts longer.
P.S-Don't worry Psychosocial, the issue affects only about 1% of the drives sold, may be you'll get lucky.
tkin is offline
Seagate 500GB or WD 640GB??????? george101 Hardware Q&A 20 02-08-2008 11:35 AM
Seagate Barracuda 7200.11 500GB OR WD CaviarŪ 500GB SE16 sam9s Hardware Q&A 6 19-02-2008 10:30 PM
128 mb GF4 440 mx showing 32mb!!! sav_more Software Q&A 8 20-10-2004 04:49 PM
