Old 20-11-2008, 03:13 AM   #1 (permalink)
OSS Enthusiast!
nitish_mythology's Avatar
Unhappy Spilled tea on Laptop!!
I have a five year old compaq laptop. By my sheer carelessness...I spilled hot tea on the keyboard!!
The laptop refused to work for some time...but after it was perfectly dried...it started working well..
The only problem m facing is with the keys... they are hard (perhaps due to tea) less responsive and i need to really press them to get the job done!
M staying in Noida...what kind of a service maintainance is required?? Moreover i dont have any bills or receipt of the lappy as it is five years old...
What to do??????? Help me out guys...
Do you know, Shinigamis only eat apples???
nitish_mythology is offline
Old 20-11-2008, 03:31 AM   #2 (permalink)
MMO Addict
amitava82's Avatar
Default Re: Spilled tea on Laptop!!
buy a replacement keyboard from ebay. Cheaper than service center. search by model number. you should be able to get one.
Steam Profile || Personal Page
Warp drive active. Approaching stargate.
amitava82 is offline
Old 20-11-2008, 07:13 AM   #3 (permalink)
JojoTheDragon's Avatar
Service center will get the job done. But they are only after commission. Dey might charge you little high rate.
| Steam: jojothedragon | Origin : jojothedragon | PSN : jojothedragon |
TDF @ Steam
Get 2GB of free cloud space : http://db.tt/OJKPcZnY
JojoTheDragon is offline
Old 20-11-2008, 08:27 AM   #4 (permalink)
Can you hear it..??
windchimes's Avatar
Since the problem is only with the keys and if you haven no stains you can complaint about key troubles.. and dont mention abt hot tea..that may work..rt?
"Just Keep swimming"
windchimes is offline
Old 29-11-2008, 01:30 AM   #5 (permalink)
OSS Enthusiast!
I asked a friend of mine to enquire...he contacted the service center guy...n he says we wont accept the laptop.
Old 29-11-2008, 06:07 AM   #6 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
Try this (rather risky) procedure:
Remove batteries, ram, hdd and other removable parts and if they are clean, keep them away safely.
Soak in mild detergent water for an hour or two.
Rinse in ordinary water after some time.
Wipe it clean and then dip in concentrated ethanol.
This is supposed to absorb the water present inside.
Keep outside to dry. Alcohol vapourises quickly.
All this only if the problem is due to some sticky sugary tea which is stuck to the keys.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 29-11-2008, 11:54 AM   #7 (permalink)
Intel OCer
amitash's Avatar
I would rather pay the service guy than do that...Xtremely risky procedure
My site: collegeclassroom.org
amitash is offline
Old 02-12-2008, 01:24 AM   #8 (permalink)
OSS Enthusiast!
Yeah seems much more than I can handle...
Old 02-12-2008, 05:50 AM   #9 (permalink)
The Smaller Bang
^^Is it the 128mb ram walla lappy in which you run Zen ? What model is it ?
Old 02-12-2008, 07:33 AM   #10 (permalink)
Juke Box Hero
Call in the service guy for the cleaning, else let it be if not bothered. The moisture would eventually make the keys soft by the pressure applied while using.
On a funny note, how would you handle this?
Hitboxx is offline
Locate Laptop - locates your stolen laptop! parthbarot Technology News 11 16-03-2008 11:29 AM
MOST EXPENSIVE LAPTOP - Luvaglio announces world’s most expensive laptop techtronic Technology News 1 27-03-2007 02:19 PM
Laptop Lan Config error work only with laptop not with pc minniawochat PC Components / Configurations 4 19-09-2006 03:21 PM
