Old 19-11-2008, 06:48 PM   #1 (permalink)
Default PC Automatcally Shutdowns!!!
This problem has started since a few weeks!I dont know why but my pc just shutdowns automatically!
The load due to which my PC Shutdowns now,was working perfectly,without any problem a few months back!!
My System is almost 2 yrs old:
Mainboard : Intel D101GGC
Processor : Intel Pentium 4 506J @ 2666 MHz
RAM : Dynet 1024 MB (2 x 512 DDR400, 3-3-3-8)
Video Card : ATI RADEON XPRESS 200 Series(on board)
Monitor : Samsung SyncMaster 732n+
Hard Disk : SAMSUNG HD080HJ (80 GB - SATA 2)
PSU : CIL-OODYSSEY AUGUST 2007 450W
+5V ......34A
+12V .....14A
-5V ........0.5A
-12........0.8A
+3.3V....28A
+5VSB....2A
TOTAL......450W
PLZ HELP GUYS !!
girishpaiv is offline
Old 19-11-2008, 07:06 PM   #2 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Default Re: PC Automatcally Shutdowns!!!
Well, it's starting.
So mobo failure isn't there.
Well, it's a PSU fault(kharab ho gaya)
It happens sometimes
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 19-11-2008, 07:14 PM   #3 (permalink)
Guys,can u pls suggest some good softwares(or methods) to control fan speeds?
lemme try controlling temp!!pls
Old 19-11-2008, 10:28 PM   #4 (permalink)
RMN
Speedfan
DELL SP2008WFP|Cooler Master Elite 330 Cabinet|MSI P45 NEO-F|Intel Q6600|Palit HD 4850 Sonic|VISTAx64|Cooler Master PCAR-600|Transcend 2GB 800M|Creative SB LIVE!Ext.|Logitech Combo EX-90
RMN is offline
Old 19-11-2008, 10:33 PM   #5 (permalink)
Krazy_About_Technology's Avatar
Ya its definately a SMPS fault. If motherboard had any problems, it wont start up.
Dell Inspiron 1525 - C2D 2 Ghz, 3GB, 250GB, X3100 :)
Samsung Omnia Pro B7610 with Stock WM 6.1 ROM
Blog: http://www.sumitbhardwaj.co.in/blog
Krazy_About_Technology is offline
Old 19-11-2008, 10:58 PM   #6 (permalink)
Section Moderator
gopi_vbboy's Avatar
if u changed to new ram recently....check whether its frequency is supported by ur motherboard
gopi_vbboy is offline
Old 19-11-2008, 11:06 PM   #7 (permalink)
JojoTheDragon's Avatar
Change your SMPS.
| Steam: jojothedragon | Origin : jojothedragon | PSN : jojothedragon |
TDF @ Steam
Get 2GB of free cloud space : http://db.tt/OJKPcZnY
JojoTheDragon is offline
Automate System Shutdowns and Restarts with GShutdown gary4gar Open Source 7 10-04-2008 04:21 PM
PROBLEM:pc shutdowns even before the first screen saurabhsun Hardware Q&A 1 24-01-2007 03:08 PM
