Old 19-11-2008, 03:03 PM   #1 (permalink)
Arrow need driver
i m having jil 0606
tv tuner card by
frontech
google no help
frontech website no help
if some 1 hv plz
jmsajid@gmail.com
if any thing u can help plzzz
i called frontech people
and told them so many thing
about hell website of frontech
and they said
"sorry"
ahhhhhhhhhhhhhhh
plz help if any 1 hv mail me
if u r in hyd plz tell me i will come
jmsajid is offline
Old 19-11-2008, 04:48 PM   #2 (permalink)
Default Re: need driver
http://list.driverguide.com/list/company2409/
realdan is offline
Old 19-11-2008, 05:17 PM   #3 (permalink)
sidewinder's Avatar
if its an internal card then i just might be able to help you !
In fact most of the internal entry level card are based on philips 7130/7134 chipset and they work fine wit generic driver
I have a techcom internal tv tuner. But whenever i install the official driver downloaded from techcom website the card is recognised as frontech tv tuner card.It seems Techcom actually uses frontech driver coz bot of them uses same chipset under the hood.
I can mail you that driver. I f you wanna give that a try then do PM me wit your e mail address..I will mail you that driver.
Bombina rocks
sidewinder is offline
Old 19-11-2008, 05:28 PM   #4 (permalink)
tnx
ok i got one <jindabad google>
i will try tomorrow i will tell u
but any how then i will need 1 sw for
run program
plz mail me i will need that too
jmsajid is offline
Old 19-11-2008, 05:33 PM   #5 (permalink)
sidewinder's Avatar
Originally Posted by jmsajid View Post
tnx
run program
Have you lost ur original cd that came with the card ????? if yes then it might be very difficult for you !
In fact the card will work fine with proper generic driver installed but the remote wont without the official program.
Yu can use many softwares available to watch the TV but remote wont work.Even Nero will work !
Bombina rocks
Old 19-11-2008, 05:50 PM   #6 (permalink)
and the damn frontech company cannot provide a copy for download? what a company!
realdan is offline
Old 19-11-2008, 05:51 PM   #7 (permalink)
i lost that cd
i hv no problum if remote will not work
jmsajid is offline
Old 21-11-2008, 12:24 PM   #8 (permalink)
i lost that cd
problum solved
any tv tuner card cd
remote also working
yap peeeeeeeeeeeeeeeeeeee
jmsajid is offline
Old 26-12-2008, 12:14 PM   #9 (permalink)
problum solved
remote also working
Can Pls send details hows your remote is working?
samirshah8 is offline
Old 29-12-2008, 10:52 AM   #10 (permalink)
Cool Re: need driver
go to proogran files
find wr u extratct evrything
then go to that folder
and find 1 application for remote make desktop shortcut
start and see working r not
that appli.
is like winremote somthing
jmsajid is offline
LAN Driver Krazzy Warrior Networking 7 12-03-2009 02:05 PM
lan driver magneticme200 Software Q&A 17 19-05-2008 08:53 AM
Where is my Driver ?? i_hate_computer Software Q&A 4 04-01-2006 02:40 AM
Driver available ????????? sagargv Software Q&A 11 06-09-2005 01:12 PM
