Old 18-11-2008, 10:36 PM   #1 (permalink)
Default display problem
system
hp pavilion 6020in
window vista home basic
history
recently upgraded RAM to 2x1GB from 2x256MB
problem intermittent in nature
no disply,no bios screen,key board inactive (some time key board leds glow once),no beep sound
action taken
monitor checked ok (vga con removed monitor shows cable disconnected)
RAM checked one by one in diffrent slots
RAMS removed beep sounded
ckecked for any loose connector
after several on off problem vanishes
pease help in further diagnosis
Mother board issue?
loose connectors?
naiyer2006 is offline
Old 18-11-2008, 10:50 PM   #2 (permalink)
damnbadman666
damngoodman999's Avatar
Default Re: display problem
Originally Posted by naiyer2006 View Post
system
hp pavilion 6020in
history
action taken
Mother board issue?
loose connectors?
i can say u one thing in any case laptop will not be a good upgrader like desktop , laptop uses little power
anyway check your bios
damngoodman999 is offline
N72 - display problem ! nav33n Buying Advice 5 21-04-2007 05:39 PM
Display problem??? Curious Guest QnA (read only) 5 14-02-2007 10:53 PM
Display Problem salztech Hardware Q&A 4 14-07-2006 11:44 PM
Display Problem Nimtshey Hardware Q&A 12 27-10-2005 01:16 AM
problem regarding display in hl2 HellGuardian Gamerz 11 20-08-2005 04:57 PM
