Old 18-11-2008, 03:48 PM   #1 (permalink)
static_x's Avatar
Arrow Mid Range Motherboard (Under 7k)
Dear All,
Kindly suggest me a motherboard under 7 K. Also whether i should opt for a DDR3 supporting mobo or not?
I'm thinking of going for MSI P7N SLI-FI. It is available for 6.5k (DDR2)
Abit's Abit IP35-E is also a consideration for me....
what you say guys??
static_x is offline
Old 20-11-2008, 09:57 AM   #2 (permalink)
static_x's Avatar
Default Re: Mid Range Motherboard (Under 7k)
what has happened to you guys....no replies....
static_x is offline
Old 20-11-2008, 10:37 AM   #3 (permalink)
╬Switch╬'s Avatar
I think this should be in Q and A section.
That might get you some answers.
There are 10 types of people. Those who understand binary and those who don’t…
╬Switch╬ is offline
Old 20-11-2008, 01:21 PM   #4 (permalink)
Violent serenity.
Psychosocial's Avatar
Hey, go for BioStar i45 if you can get it. Best mobo in your price range. If not, settle for MSIP7N Digital. DDR3 support is a waste. BTW, is your CPU Intel or AMD. If its Intel, the mentioned mobos will work. If its AMD, get a Jetway 780G.
Psychosocial is offline
Old 20-11-2008, 04:35 PM   #5 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
MSI P45-NEO F @ 5.8k
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 20-11-2008, 05:18 PM   #6 (permalink)
Violent serenity.
^^i45 beats it in every way possible. And its around 7k. Tell me one reason to buy the P45 Neo over it.
Old 21-11-2008, 04:03 PM   #7 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Biostar i45 is an AWESOME BOARD
Din think 'bout it then
About me:
Old 21-11-2008, 04:06 PM   #8 (permalink)
DDR3 is the future. DDR2 will eventually become obsolete. Make sure you buy one that supports DDR3.
Core i7 965 Extreme is offline
Old 21-11-2008, 09:10 PM   #9 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Yeah, putting freakin DDR3 on a FREAKIN old PC(comparitively) is NO USE
DDR3 isn't the need or choice for another 2 years unless u r gonna go for NEHALEM OR DENEB by nxt year Q2
About me:
GFX card in 2k-3k range? pranav1994 Graphic cards 11 04-06-2009 10:53 PM
Need HTPC configuration ! (Low range / Mid range) blackbird PC Components / Configurations 19 02-04-2009 04:36 PM
Motherboard in the 3k to 3.5 range NaifAmoodi Reviews 19 26-09-2008 11:44 PM
pls suggest a good CPU-Motherboard combo within Rs.12k for a mid-range gaming machine abhishek.bandodkar Gamerz 2 22-08-2007 08:40 PM
Fc 6--->Sync out of range Cool G5 Open Source 23 21-03-2007 10:38 PM
