hi santapg......
im using
cpu:- intel pentium 4 506
mother board:- intel D101GGC
hard disk:- 80GB
dvd writer:- LG wr
i have two ddr slots and im usin 256MB and 512MB rams
i want to buy 1GB ddr2 800 ram newly so that i think my pc speed can increase since i play games which use more ram for processing. In that i want to remove 256MB ram and replace it with 1GB.
i dont use any extra graphic cards.
so please tell me
1. is it possible to add 1gb ram to my pc
2. if possible , 1gb ddr2 800 is enough or should i use another
3. suggest me best graphic cards i can use in sequence of high price to cheaper.
another imp query:
My dvd is not writing or reading anything from cd's. it works well with dvd's.
when i bought that it worked fine i dint remember wether i burn cd's at that time.
so, is there any problem with writer or is my writer is capable of writing dvds only.
also tell me the best dvd writer i could buy around 1500/- in india andhra pradesh.
i'll be waiting for ur precious suggestions, thank u.
