Old 17-11-2008, 07:49 PM   #1 (permalink)
Unhappy Problem in Monitor
Hi Guys, I'm in trouble with my HCL (HCM780M) monitor for the last couple of weeks n now request if any of you can give me a solution to it. The trouble is, immediately after getting connected to power, the control window of the monitor appears and it goes out of control of the monitor-buttons. No button can close or adjust any of the functions embodied therein. The indicator remains on 'contrast' button and then suddenly it begins to move one after another button speedily and after some time it closes automatically. As a result, the size of the windows sometimes gets vertical, smaller, sometimes brightness or contrast comes down from the normal ones. I'm using this monitor since 4 years. Is there any solution to this hitch?
Kerry is offline
Old 18-11-2008, 03:16 PM   #2 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
Default Re: Problem in Monitor
u need to service the monitor....this problem is common among crt monitors.
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 18-11-2008, 08:36 PM   #3 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
^^ as its been 4 yrs.. n also its a CRT.. it must be on its last gasp of life.. nothing else can be done... vetter get a LCD monitor..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is online now
LG CRT Monitor problem. Ashok Verma Hardware Q&A 3 07-07-2008 04:25 PM
Monitor Problem sharma_sanjay_s Hardware Q&A 4 13-12-2007 12:21 PM
Monitor Problem bizzare_blue Hardware Q&A 5 12-11-2006 06:41 PM
MONITOR PROBLEM( in 17'') nittn_only_4u1 Hardware Q&A 2 23-01-2006 06:12 PM
Monitor Problem Panda QnA (read only) 5 18-09-2005 08:11 PM
