Old 17-11-2008, 04:21 PM   #1 (permalink)
Post Help required for best motherboard selection.
Dear Guys,
Please suggest a good motherboard for Intel Core 2 Duo E8200 and AMD Phenom X4 9550+ processors.
The following are my requirements:
1) It should have IGP.
2) The price should be less than INR 6000/-.
3) It should support 8GB RAM in dual channel mode.
4) It should have DVI video output.
5) It should have IEEE1394/Firewire port (at least one).
6) The IGP should be able to handle all the latest 3D Desktop effects in Windows Vista and Linux (like Compiz in OpenSuse 11).
7) It should have at least 2 IDE ports.
Please help me to choose a best motherboard by providing your valuable suggestions. (Please suggest the motherboard for both AMD & Intel platform).
Thank you,
Regards,
Akshara.
aksharatg is offline
Old 17-11-2008, 05:36 PM   #2 (permalink)
Rallying The Rig
booobooo's Avatar
Default Re: Help required for best motherboard selection.
Graphics: Palit 9600GT 512MB : 06600.00
Processor: Intel Core 2 Duo E8400 6MB L2 3.0Ghz.1333Mhz. : 09100.00
Mother Board: MSI P45 Neo-F DDRII 1333Mhz. Support : 05600.00
You Can Over Clock It Too And Exceeds All Yiur requirements...
booobooo is offline
Motherboard required yash.yash Hardware Q&A 1 14-04-2008 08:53 AM
Information required regarding motherboard Itz_Me!!! Hardware Q&A 1 11-02-2008 07:00 PM
Motherboard & CPU Bundle - Suggestion Required sainit Hardware Q&A 2 08-04-2007 11:14 AM
motherboard help required pls!! prankzter CPU / Motherboards 2 01-02-2005 11:50 AM
Motherboard Selection doom_marine CPU / Motherboards 8 26-11-2004 05:44 PM
