Old 17-11-2008, 03:26 PM   #1 (permalink)
soyab0007's Avatar
Default Motherboard Under Rs2500
I need a Motherboard Under Rs2500. For intel processor.And it should have inbuilt good graphics cards. Which Motherboard should i go for except intel
soyab0007 is offline
Old 17-11-2008, 03:38 PM   #2 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
Default Re: Motherboard Under Rs2500
Two choices:
1. nVidia 610i chipset - ASUS or Palit - no dual channel but good looking graphics GF7050
2. Intel G31 Chipset - Gigabyte - dual channel support but graphics *just* enough for AERO GMA 3100.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 17-11-2008, 04:22 PM   #3 (permalink)
Excessive happiness
furious_gamer's Avatar
As MetalHead said....
I prefer you to get the ASUS P5N MX or Palit N73V, both falls under your budget...
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
Last edited by furious_gamer; 17-11-2008 at 04:24 PM. Reason: Automerged Doublepost
furious_gamer is offline
Old 17-11-2008, 05:22 PM   #4 (permalink)
soyab0007's Avatar
Can i get nvidia 7100 under this budget.
Old 17-11-2008, 05:41 PM   #5 (permalink)
Excessive happiness
May be... check that in itwares site.....
PS Request
Old 17-11-2008, 05:43 PM   #6 (permalink)
The Smaller Bang
7100 is quite hard to get at 2.5K. But it comes at Rs. 2,900 easily.
Old 17-11-2008, 05:45 PM   #7 (permalink)
Excessive happiness
No use in getting 7100 as most of new games will stutter with that card.. even it couples with a C2D proccy..
PS Request
Old 17-11-2008, 05:54 PM   #8 (permalink)
The Smaller Bang
Duh.. he means GeForce 7100 Chipset.
Thats 630i to you
And I doubt he has a high end CPU when his budget is this low.
Old 17-11-2008, 06:17 PM   #9 (permalink)
jayavardhanarao's Avatar
Go for BioStar Mother board with intel G51 shipset
jayavardhanarao is offline
Old 17-11-2008, 06:32 PM   #10 (permalink)
Violent serenity.
Psychosocial's Avatar
^^Awesome \m/
@OP
go for ASUS P5K PLVM.
Psychosocial is offline
Old 17-11-2008, 08:18 PM   #11 (permalink)
The Smaller Bang
Yeah, when it comes in 2009 Q4 supporting only Nehalem, I definitely urge you to buy it
Originally Posted by Psychosocial View Post
^^Awesome \m/
@OP
ASUS P5K PLVM ? Not advisable since onboard graphics is bad.
On the other hand, if he is getting a GPU, its a fine choice.
@OP: whats your current rig ?
Old 17-11-2008, 08:45 PM   #12 (permalink)
mihirpradhan2004's Avatar
Go for Asus P5N-MX
mihirpradhan2004 is offline
Old 17-11-2008, 10:54 PM   #13 (permalink)
soyab0007's Avatar
Can you tell me which company can give me best service and quality.
Asus
Palit
Gigabyte
Biostar
Old 17-11-2008, 10:56 PM   #14 (permalink)
Violent serenity.
^^Depends. I prefer ASUS and BioStar out of this group.
Old 18-11-2008, 01:47 PM   #15 (permalink)
Excessive happiness
Asus
PS Request
Old 18-11-2008, 02:40 PM   #16 (permalink)
Violent serenity.
^^Tell me why ?
Old 18-11-2008, 03:39 PM   #17 (permalink)
Excessive happiness
Cuz i have it...
PS Request
Old 18-11-2008, 10:19 PM   #18 (permalink)
soyab0007's Avatar
Which one better Asus P5N-Mx or Palit N73V
Old 18-11-2008, 10:42 PM   #19 (permalink)
Violent serenity.
P5n-mx
Which Motherboard Should I Go For??? thunderwonder Hardware Q&A 4 09-01-2008 03:33 PM
Which Motherboard I must Buy? mrintech CPU / Motherboards 2 01-01-2008 05:23 PM
CPU + Motherboard tharkiman Hardware Q&A 3 20-01-2007 07:24 PM
Motherboard parimal_xp2003 CPU / Motherboards 4 22-06-2005 12:05 AM
