Old 17-11-2008, 01:16 PM   #1 (permalink)
Unhappy USB Drives (jump/ flash/external etc..) not working
I found that only USB Drives (jump/flash/external/etc.) are not working on USB ports, other things like mice etc... are working perfectly, on my laptop.
On connecting USB drive the we can see the USB drive in Disk drive (in Device Manager), but the in Storage volumes Generic volume is showing yellow mark, which is not resetting even on uninstalling/ installing.
I am using Windos XP SP3. Is the antivirus can disable this? Their is Symantec ANTIVIRIUS has instaaled in my computer.
Kindly help me in resuming the same.
Rajesh Soni is offline
Old 18-11-2008, 07:46 PM   #2 (permalink)
Default Re: USB Drives (jump/ flash/external etc..) not working
after uninstalling it using the device manager.did you reboot?
you could try to find for the windows xp usb driver somewhere..as yours might be corrupted
realdan is offline
USB & external drives not working Rajesh Soni Hardware Q&A 2 13-11-2008 01:42 PM
whats the difference between External hard drives and HDD based MP3 players moshel Software Q&A 1 21-08-2008 04:07 AM
Reg Jump: Jump into the registry adi007 Tutorials 9 18-03-2008 09:34 PM
How to disable USB Drives (jump/flash/external/etc.) dinesh_ymca Tutorials 12 19-11-2007 06:26 PM
All About ReadyBoost - Compatible & Incompatible USB Flash Drives topgear Hardware Q&A 2 04-08-2007 01:33 PM
