Okay i am also in the process of building a Nas for my home...
Same thing as you are in here are my research you can check and u might get what u want
THis might mislead you but information is never harmfull
1) You can mod a Linksys router and load a firmware like dd-wrt as per your requirement.
2)
http://www.qnap.com/pro_detail_feature.asp?p_id=78
3) Check out the Via PICOATX or Nano atx
http://www.via.com.tw/en/products/em...tigo/index.jsp
http://www.portwelllaxsons.com
Checp nas and benchmarking.... (not that cheap)
http://www.hardforum.com/showthread.php?t=1283900
How to get Maximum Output from you LAN card !!!!!
http://www.hardforum.com/showthread.php?p=1032170858
Athlon Atom Nano Compared Low Power Review
http://www.tomshardware.com/reviews/...ower,2036.html
3.5 hard disk Chart Compared (i know you don't need one for router)
http://www.tomshardware.com/charts/3...arks-1,24.html
Toms Hardware (Athlon Atom Nano Compared Low Power Review)
Next year, Intel will launch its Moorestown CPUs, which are supposed to include a memory controller as well as a graphics unit right on the CPU die.
Personal Suggestion
Some jetway product provide a motherboard which is compact and can have 4 Lan port..
And still they are mini itx
www.mini-itx.com
use pico itx (if possible)
Cheapest NAS with Bit Torrent support ?
Non-PC Torrent Client
Update = First of all check it with your local dealer if they provide the product or your time will be wasted..
Get the contact number of
Gigabyte
Jetway (if available in india)
MSI
Intel
asus
Biostar
And check the availibilty of the product by calling them...
