Old 15-11-2008, 09:57 PM   #1 (permalink)
Deadly Creature Me!
ubersoldat's Avatar
Unhappy Combo Drive unable to read CD's!
Hi,
I have a LG Combo Drive (HL-DT-ST RQ/DVD GCC-4522B) and it cannot read or write any type CD's. . I have cleaned the lens and it can read old Digit dvd's and movie dvds without any issues. So the problem lies only with CD's! . Can anyone pls tell me whats the cause for this and a solution would be grateful. Pls don tell to buy a new drive becos i don have a penny .
Bye
ubersoldat is offline
Old 15-11-2008, 09:59 PM   #2 (permalink)
Default Re: Combo Drive unable to read CD's!
Problem with new CDs only or old ones as well?
ThinkFree is offline
Old 15-11-2008, 10:02 PM   #3 (permalink)
Deadly Creature Me!
ubersoldat's Avatar
Talking Re: Combo Drive unable to read CD's!
Hi, It cant read any type of CD. Re-Writable, CD-ROM, CD-R, pressed CD, burnt CD, new CD, old CD, blank CD and not even Digit CD's! (lol).
Bye
Old 16-11-2008, 01:08 PM   #4 (permalink)
How old is the drive?
What happens after you insert a CD into it. Does it keep blinking the front panel LED forever?
Does ur explorer hang after that if you try to access it
patkim is offline
Old 16-11-2008, 02:53 PM   #5 (permalink)
Wise Old Mouse
mrintech's Avatar
Go buy a Lens cleaner and run it in your drive after reading the instructions. Also mind that your CD's and DVD's are in healthy state.
Don't use scratched CD and also some sort fo cleansing solution for CD/DVD come, use it to prevent tiny dust particles from entering your PC
- MrinTech :)
mrintech is offline
Old 16-11-2008, 04:33 PM   #6 (permalink)
Deadly Creature Me!
ubersoldat's Avatar
Exclamation Re: Combo Drive unable to read CD's!
@Patkim, Drive is about 4 yrs old and it cant read CD's whatsoever . The LED doesnt blink forever. And when I click on the drive, it gives me the message, pls insert a disk. Whats bugging me is it can read DVD's without any probs, even scratched dvd's . And this sh*t drive cant read newly burnt or old cd. I tried Samsung, Sony, TDK, Mbaer, MMore, Eurovision and other unbranded Cd's but the issue still persists. Its just not recognising any type of CD's
@Mrintech, used Lens cleaner. Still problem is not solved.
Combo drive LG GCC 4522B doesn't read DVD's dabster Hardware Q&A 4 06-04-2007 12:25 PM
combo drive problem read some dvd dosen't read others q4_abhi Hardware Q&A 4 03-04-2007 05:09 PM
Samsung's DVD Combo unable to read NFS MW Disc... BBThumbHealer Software Q&A 8 25-01-2007 05:26 PM
CD DRIVE UNABLE TO READ CD'S rahulshankar Software Q&A 5 17-04-2006 01:39 PM
not able to read Digit Cd's --URGENT online_marketeer QnA (read only) 8 20-03-2005 04:32 PM
