Old 15-11-2008, 10:01 AM   #1 (permalink)
Default shared video memorey problem
My frd has
a 2gb ram and he using my onboard graphics...
the problem is that the dedicated memory of his video card is 256MB and 639MB of his ram memory is shared with his video memory making a total video memory of 895MB which is really affecting his pc's performance.
Is there any way to remove the shared memory
chipset---------> amd 780g
2 gb transcend 800mhz ram
join my orkut community to download latest movies, music & games here's the link to view it http://www.orkut.com/Community.aspx?cmm=38665088
Blackfire is offline
Old 15-11-2008, 10:13 AM   #2 (permalink)
Wise Old Mouse
mrintech's Avatar
Default Re: shared video memorey problem
Go to BIOS (Press Del Repeatedly during startup) and there will be some display setting... Go lower the Memory from there..... 64 MB will be sufficient....
It will be quite cool if you do this in presence of a friend who knows BIOS. Be cautious and refer BIOS Manual if you feel uncomfortable.....
- MrinTech :)
mrintech is offline
Old 15-11-2008, 11:17 AM   #3 (permalink)
At Hell's Disq
hellgate's Avatar
Originally Posted by Blackfire View Post
My frd has
cudnt quite get u?
r u using onboard gfx or a dedicated gfx card?
if its a dedicated gpu sudnt cause probs even if it shows that sys ram is shared with the gfx card cuz this shared ram is used only in cases where the onboard vram of the gpu is filled.
hellgate is offline
Problem with shared folder CadCrazy QnA (read only) 4 24-09-2007 12:01 PM
How to increase shared memory (I have 768 MB ram 64MB shared) azharuddin_aawan Hardware Q&A 2 20-02-2007 10:22 PM
shared video memory churchinvirus Software Q&A 13 24-10-2005 12:14 AM
Problem....Cant Increase The Shared Video Ram?? rollcage QnA (read only) 7 08-07-2005 03:57 AM
Plezzzee Help Me Regarding Shared Video Memory sujithtom Software Q&A 10 29-10-2004 09:23 PM
