Old 14-11-2008, 06:58 PM   #1 (permalink)
Thor's Avatar
Cool Should I go for the RAM Upgrade ?
Hey there friendlies!
I own a Compaq Presario V3425AU which I got around end of July 2007.
These are its specs :
1.71 GHz AMD 64bit Athlon X2
1 GB DDR2 667 MHz RAM ( 2 x 512 )
160 GB HDD
nforce chipset with onboard GeForceGo6150 ( now sharing 256MB memory)
and the regulars like wifi , bluetooth , dvdrw etc etc
Running Windows XP
I generally play occasional games, nothing too demanding as I know with 6150 chipset its foolish to expect the laptop to run latets games. But what I do expect it to run is occasional Role Playing Games , Strategy games released till 2006 - 2007. I hope I am not setting my Hopes too high only to be dashed! mg:
With 1 GB DDR2 RAm I found that Neverwinter Nights 2 lags ! What a bummer, now that I have some cash handy , I am considering upgrading the RAM. Right now I have 2 x 512 667Mhz modules. I am thinking of replacing one of the two 512 MB modules with a 2 GB module.
How much performance gain can I expect ? With 2.5 GB of RAM Can I expect them strategy and RPGs to run better ?
Help please! :whiteflag:
Beware of my Wrath Mortals, Thou hast no choice.
Thor is offline
Old 14-11-2008, 07:40 PM   #2 (permalink)
Default Re: Should I go for the RAM Upgrade ?
I have vista basic on my compaq v6608au laptop. with turion tl58 and 512MB*2 DDr2 Ram.Just two weeks back replaced one 512 MB with a 2GB DDR2 SODIMM. Still vista shows the same free available RAM which rarely crosses 200 MB. Since you have got a Win XP installation surely this will increase the performance considerably. I bought this 2 GB for Rs.1600 in Chennai.
squid is offline
Old 14-11-2008, 08:41 PM   #3 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
^^ u can surely expect sum increase in game performance, (but) do not expect to run these games at higher settings.. (bcoz) of the onBoard GeForce Go chipset..
still, its never bad to increase the RAM eiter on a desktop or on a lappy, but do get it installed (upgraded) by a Compaq's technician.. preferably in their own service center (coz u knw the hassels u might face if sumthing goes wrong if u hv installed RAM from sumwhere else than the Compaq Service Center..) ..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is online now
Old 16-11-2008, 10:51 AM   #4 (permalink)
the thing is you should buy one compatible for your particular laptop..and there are options to check it at memory vendor websites..ex:crucial.com
the rest is just opening the right place under your laptop and installing is lego-like
realdan is offline
Old 16-11-2008, 01:01 PM   #5 (permalink)
Cool Buddy's Avatar
buying 2 1GB modules could be better as they would work in dual channel, however I'm myself confused about this concept of dual channel, do 2 1GB modules really work in dual channel or we have to buy 2GB kit I'm still confused.
Nokia 5230 :(
Canon IXUS 115 HS :)
Cool Buddy is offline
Old 17-11-2008, 02:23 AM   #6 (permalink)
http://en.wikipedia.org/wiki/Dual-channel
realdan is offline
9600GT Without Upgrade or 8600GT With Upgrade pratik03 Hardware Q&A 23 31-03-2008 12:20 PM
Upgrade woo-hoos to Upgrade blues. Help! mightyboosh Hardware Q&A 1 27-11-2006 12:14 AM
AMD system upgrade..err??no u all bored of upgrade forums but pls do help me...!! karthik316_1999 Internet & WWW 11 18-07-2006 08:10 PM
graphic card upgrade(PCI) or motherboard upgrade? thetopcyborg Graphic cards 5 13-01-2006 02:32 PM
