14-11-2008, 02:27 PM
Help: Samsung LCD does not detect PC input
i decided to buy a LCD TV instead of LCD monitor. I have yet to buy a CPU. Yesterday i decided to test how vista appears on my LCD TV. so i and my friend (owns a sony vaio running vista) decided to test it out. we connected the lap top to the LCD via the PC input (VGA/D-sub 15 pin).
Now here is the problem: we started the TV, we started the Laptop, the laptop detects a secondary display attached to it. we configured it, but due to some reason that we are unable to find out, the LCD is refusing to detect a input at the PC input. Samsung LCD that i have has a feature (mine is LA26A450 model) that they toggle only between those sources which are connected. When i went to the menu for selected the input, the PC input is disabled, meaning it does not detect the input (we also tried the Fn+F5 key for secondary display on the lappy). So i called another friend who has a laptop (compaq, very old, just 256 MB ram, running XP). we tried the same thing but same result, the PC input stays disabled. We also tried varying the resolutions, from highest to lowest and also played around with the refresh rate. the recommeded is 60 Hz by the TV manual.
I did some googling, where i found that some samsung LCD, not my particular model have compatibility issues with the sony vaio but they work fine with desktops, so i called another friend with his CPU and keyboard mouse (intel core2duo 3GHz, 945 intel chipset, running vista, 2 GB ram). The desktop boots (We can hear the welcome note) but still the LCD does not detect the PC input.
Does any body know what am i doing wrong? or what will make it work?
14-11-2008, 02:45 PM
Re: Help: Samsung LCD does not detect PC input
u sure your vga cable is fine?
VIDEO Screen Size 26"
Resolution 1,366 x 768
Dynamic Contrast Ratio 5,000:1
Viewing Angle 176°/176°
Response Time 8ms
DNIe™ DNIe +
Brightness 450
Backlight CCFL
LCD 100Hz No
AUDIO Sound Output(RMS) 5W x 2
Sound Effect System SRS Trusurround XT
Input & Output(Side) HDMI 1
composite (AV) 1
S-Video 1
Headphone 1
WISELINK (USB) No
WISELINK (Multi Memory Slot) No
WISELINK (etc.) No
Cabinet Swivel (left/right) No
Feature Picture-in-Picture 1 Tuner PIP
Sleep Timer Yes
Clock & On/Off timer Yes
Still Picture No
Auto Channel Search Yes
Auto Power Off Yes
Auto Volume Leveller Yes
Anynet+ (HDMI-CEC) Yes
Movie Plus No
TTXT 1000p
System Colour System PAL Multi
Power Free
Dimension Set size(WXHXD) with stand 669.7 x 500.4 x 216mm
Set size(WXHXD) without stand 669.7 x 450.7 x 90mm
Package(WXHXD) 766 x 168 x 572mm
Weight Set weight with stand 9.7kg
Set weight without stand 8.3kg
Package weight 13.5kg
Accessory Wall Mount VESA Standard
Remote Controller TM96B
Batteries, AAA type Yes
ANT- Cable No
Power Cable Yes
Input & Output(Back) RF Input 1
Component(Y/Pb/Pr) 2
S-Video No
Headphone No
Composite(AV) 1
HDMI 2
PC input (D-sub) 1
Video Monitor out, L/R 1 (Audio out)
Optical sound out No
RS232C (for Service only) 1
Power consumption Operation power consumption TBD
Stand-By power consumption <1W
14-11-2008, 09:10 PM
Core i7 (nehalem) Owner
to the OP:
did u not try connecting a normal PC CPU (and NOT a lappy) to the TV ??
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
14-11-2008, 10:19 PM
^^ yep he did.
i suggest you try a diff cable.
DELL SP2008WFP|Cooler Master Elite 330 Cabinet|MSI P45 NEO-F|Intel Q6600|Palit HD 4850 Sonic|VISTAx64|Cooler Master PCAR-600|Transcend 2GB 800M|Creative SB LIVE!Ext.|Logitech Combo EX-90
14-11-2008, 10:37 PM
Indidiot
I use my Samsung LCD TV and PC display with my desktop. It has been one year and it hasn't detected PC Input  BUT it switches to PC when I press PC button on the remote. I too tried to connect my friend's Compaq laptop to my screen but nothing happened. I suggest u better get that LCD monitor
14-11-2008, 11:41 PM
^^ im also of the same opinion.. but now tat he has already purchased it, it wud be difficult dude...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
15-11-2008, 07:14 AM
then maybe you can ask for replacement or refund...since in brand new.
15-11-2008, 09:42 AM
I think i'll check the VGA cable by connecting a laptop and LCD monitor with the same cable. if it works, the fault will probably my LCD. i'll check today evening, by the way any body know how to register case in consumer court? in case if things get rough?
15-11-2008, 12:44 PM
yup, check the cable first..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
17-11-2008, 10:14 AM
If you care for your eyes& work with computer more than 5-7 hrs then get that LCD monitor, LCD tv does not have that sharpness which a monitor has thus affecting ur eyes in the long run.
17-11-2008, 11:27 PM
yes, agreed, LCDs are really soft on eyes...and esp. no heating issues too..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
14-07-2010, 06:51 AM
Did you find the solution?
As you I bought a samsung LCD, and I got a samsung nc10.
My laptop detect the screen, but the lcd doesn't detect D-sub (pc) input?
I have Two similar lcd samsung LA32A3300J1N XT, and the D-sub cable Is new, I just bought it.
I don't unterstand?
REgards
14-07-2010, 07:14 AM
I have a samsung 32inch b550 full Hd lcd tv and using as a moniter..but I didn't have any issues like this..'
In ur remote u have to select the pc mode when u r connecting with a d sub cable..! If u r connecting through Hdmi then it should detect auto..'
P2 x4 955 B.e,ga880gm-usb3,corsair 6gb,tx650,sea 1tb+500*2,cm690 with 7 fans 120mm,curve 2000 and mx518,sony &hp optical drive,sunbeam cold cathode*2 & bubble lights,benq g2222hdl.samsung 32"full hd.
14-07-2010, 09:11 AM
In fact I'm connecting by D-sub.
And the problem is d-sub input source is disable so I can't choose it.
16-07-2010, 01:40 PM
Does anyone can help me?
I really don't understand.
My laptop is set up, for dual screening, 800x600, 60HZ. The laptop detect the TV, But the lcd screen doesn't detect the vga input source.
I have 2 different laptop, 2 same screen and 1 new vga cable.??
I really don't understand?
