Old 13-11-2008, 06:01 PM   #1 (permalink)
Exclamation 4 seagate hdd, which disk should have the OS?
NEED URGENT REPLY
I am about to format my system,
I have 4 seagate hdd having different specs ranging 2mb buffer to 32mb buffer.
Detailed spec can be checked here http://www.seagate.com/www/en-us/
ST3160211AS-160gb /2mb buffer (4yrs old)
ST3250624AS-250gb /16mb buffer (3yrs old)
ST3320620SV-320gb /16mb buffer (1.5 yrs old) this hdd has faster read/write
ST31500341AS-1.5TB /32mb buffer 120 MB/s sustained data rate
Should I load the OS on the latest HDD having 32mb buffer & use the 16mb & 2mb buffer hdd just for storage?
Need help in planning my dual boot XP/vista x64 system.
ranjan2001 is offline
Old 13-11-2008, 09:05 PM   #2 (permalink)
Default Re: 4 seagate hdd, which disk should have the OS?
Install OS on that disk which has fastest read/write speed.
ThinkFree is offline
Old 13-11-2008, 09:15 PM   #3 (permalink)
Thanks and Regards,
Prathamesh R. Tawde
prathamtawde is offline
Old 13-11-2008, 09:19 PM   #4 (permalink)
That has to be the latest 1.5TB disk then, actually I have got that disk for data storage but if its required then I will create 3 40GB each partition on it & use the rest for storage.
Where did you find that its faster than 120mb/s
On the seagate site the data transfer speed is not mentioned for ST3320620SV, but I do remember that this disk was specially made for video encoding which required faster read/write operations.
EDIT
I downloaded the spec sheet & in that its mentioned as 72mb/s sustained data transfer speed for the 320gb disk.
So the fastest is 1.5tb hdd with 32mb buffer.
1 TB Hard Disk Drive Confirmed By Seagate!!! Gigacore Technology News 6 16-03-2009 08:29 PM
Seagate ST3500320AS Hard disk in Kolkata nishant_nms Chit-Chat 2 26-10-2008 01:09 PM
Seagate SATA-1 Hard Disk Repeatedly Crashing Zaysen Hardware Q&A 12 19-07-2007 07:52 PM
