Old 12-11-2008, 12:52 PM   #1 (permalink)
Default Key Board
What is the life of a key board. I was forced to change two key boards within a span of two years? Will the key boards also affected by computer virus?
Ramasamy59 is offline
Old 12-11-2008, 12:57 PM   #2 (permalink)
Wise Old Mouse
mrintech's Avatar
Default Re: Key Board
There is no specific lifetime for Keyboards, it all depends on Usage and maintainence. Just keep it clear and covered.
Also brand matters. I am using Logitech Keyboard for the last 5 years, no problem till now.
A BIG NO.... Viruses and spyware and other malicious programs has no effect on your keyboard.
Maybe you want to get checked your MOBO ports too.
- MrinTech :)
mrintech is offline
Old 12-11-2008, 01:03 PM   #3 (permalink)
Fullbring
Zangetsu's Avatar
also depends on how u use it..
same here!!!
hmm..i wonder if there is ne Hardware virus 4 keyboard or other
Zangetsu is offline
Old 12-11-2008, 01:38 PM   #4 (permalink)
M3TAL H3AD M3
skippednote's Avatar
LOLZ....no its not just possible.
I spit Rainbows.
skippednote is offline
Old 13-11-2008, 08:48 AM   #5 (permalink)
Wise Old Mouse
mrintech's Avatar
Suppose Somehow Viruses are Invented for Keyboard, as a result of this:
Suppose you are typing and suddenly the Keyboard keys starts jumping or change their position in order to make you completely baffled.
Now in order to tackle these Keyboard Viruses, Anti-Virus Companies will make XYZ KeyBoard Anti-Virus - Stops 100% Jumping of your Keyboard Keys....
- MrinTech :)
mrintech is offline
Old 13-11-2008, 10:00 AM   #6 (permalink)
i had used techcom keyboard for like 5 years. they makes very low quality keyboards but it survived.
there is effect of virus on keyboards
rahuljin is offline
Old 13-11-2008, 10:42 AM   #7 (permalink)
Wise Old Mouse
mrintech's Avatar
Which Virus? Name it... I will install on my PC
- MrinTech :)
mrintech is offline
Old 13-11-2008, 03:40 PM   #8 (permalink)
Well, I have this cheap Chicony brand keyboard (made in China) which I got along with my 1st machine. It lasted 6-7 years thru fairly heavy use. As far as I remember, the price that time was not more than Rs. 200! It had a great "feel"... even my MS keyboard does not feel that great compared to it! Thats value for money!!
In comparision my iBall was totally unsatisfactory throught and went stone dead as soon as out of warranty.
So brand does matter a lot!
If you want a really long lasting keyboard, consider a TVS mechanical keyboard. They are supposed to last for eons. I belive they are noisier than membrane keyboards though, and cost more.
Raccoon is offline
Are graphics solutions on Intel DG31PR Desktop Board & Mobile 965 Board DIFFERENT? Krazy_About_Technology Software Q&A 8 27-08-2008 12:31 AM
Amd X2 Sli Board shift Hardware Q&A 2 22-04-2008 10:53 PM
new 939 pin board sagar_coolx Hardware Q&A 1 30-10-2007 12:55 AM
Anyone here from IB board??? Chirag Chit-Chat 1 04-06-2007 05:16 PM
Is Intel Board is the best? vasulic CPU / Motherboards 12 28-09-2005 06:55 PM
