11-11-2008, 04:43 PM
Time To Play The Game
what psu for 9800GTX?
Does CM-PCAR-500W psu enough for BFG 9800GTX 512 Mb?
This psu gives 18A on 2 rails, max wattage of 360w.
With the following specs will it run well?
Intel E7300 2.66Ghz @ 1066 FSB
Intel D945 GCNL @ 1066 FSB
Kingston 2GB Ram
Seagate SATA HDD 250 GB x 2 @ 7500RPM
CDVDR RAM Drive (Combo Drive)
Online power wattage calculators give and estimated power usage of 378w, this PSU gives 70%+ efficiency. the GFX card takes 28A from total 36Amps but if we calculate 70% of 500w PSU is 360w.
this confuses me so I need help in this regard.
PLZ help.
thanks in advance
bilal
Intel C2D E7200-Intel D945 GCNL Mobo-2 GB Kingston DDR2 RAM-XFX 9800 GTX+ 512 MB-
600w CoolerMaster PSU-160Gb SeaGate
SATA HDD-
Windows Xp Pro SP2 Genuine Validated.
11-11-2008, 04:49 PM
Excessive happiness
Re: what psu for 9800GTX?
If u r confused, then get a Corsair VX450W... Good one....
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
11-11-2008, 05:58 PM
M3TAL H3AD M3
Cool Master 600w
I spit Rainbows.
11-11-2008, 06:05 PM
Excessive happiness
Corsair VX450W = CM 600W ...  ..
Corsair one has high efficiency compared to CM one....
PS Request
11-11-2008, 06:19 PM
M3TAL H3AD M3
lol me
I spit Rainbows.
11-11-2008, 06:36 PM
AMD & ATI FANBOY
corsair have a single PCI-E connector , but 9800GTX need two ???
Go for cooler master Extreme 600watts it has two PCI-E
GAMING RIG=>C2DE8500 | ASUS P5Q PRO |3GB DDR 800 |VIEWSONIC VX1932WM|CM 600 WATTS |PALIT 4850
PC RIG=>AMD PHENOM X4 9550 | ASUS MOBO |2GB DDR 667 |CORSAIR 450 WATTS |17"TFT LG |2 TB SEAGATE
11-11-2008, 07:05 PM
ToTheBeatOfUrHeart
Yes go for CM-EP 600W as it has 2 PCI-EX power connectors.I have this PSU and to tell you its just a tad bit noisy(i took care of it by replacing the default fan by a new one for 800 bucks from Itwares)
12-11-2008, 12:26 PM
I'm also very confused about all this. I was thinking about taking corsair hx 620 to power the 9800 gtx.
now what should I do? pick up a new PSU that comes with two pci-e connectors?
12-11-2008, 12:34 PM
Excessive happiness
Then get HX620..Good one though..
PS Request
12-11-2008, 12:44 PM
I'm buying a zotac 9800 gtx amp! edition. it's coming with two 2xMolex connectors. So it shouldn't be a big problem. (I think)
Anyway I'm taking a hx620
12-11-2008, 02:57 PM
some say that crossair psu works fine only with pure sine wave ups. check this point before buying.
12-11-2008, 03:53 PM
ive been using a Cooler Master PCAR-600 for a month and the fan seems fine....
DELL SP2008WFP|Cooler Master Elite 330 Cabinet|MSI P45 NEO-F|Intel Q6600|Palit HD 4850 Sonic|VISTAx64|Cooler Master PCAR-600|Transcend 2GB 800M|Creative SB LIVE!Ext.|Logitech Combo EX-90
12-11-2008, 07:09 PM
ToTheBeatOfUrHeart
I have Corsair HX-620 too and its working fine with APC 650VA UPS.
12-11-2008, 07:25 PM
Means no problem that sound good.
Then why not to go HX450W it's enough for it and it will save some money also.
12-11-2008, 10:00 PM
EXIT: DATA Junkyard
Go for the HX620 if u can afford it, it's very good
13-11-2008, 09:07 AM
ToTheBeatOfUrHeart
No i say to be future proof stick with HX-620W.
13-11-2008, 10:12 PM
my friend is having this config..
G33 / P35 mobo (not sure which one)
Q6600 proccy
2gb ram
he is planning to Buy the Asus 9800 GTX+ AMP! edition.
what kind of a PSU will he need? please suggest the cheapest workable solution.
currently he is on stock PSU.
Reason: Automerged Doublepost
14-11-2008, 12:50 AM
and i have one pc with corsair HX620 running on APC 500VA..an older tower model
14-11-2008, 01:11 AM
#19 (permalink)
bilalarc has not even bothered to replied yet after all the recommendations.what a guy.
asus psn32-e sli,1x4 ddr2 ram,nvidia stacker case,19inch lcd,sapphire hd4850 graphic card,smps 730 w from zeb
asus g73jh lappy
14-11-2008, 06:25 AM
#20 (permalink)
he might have taken the decision and forget all about this and busy playing crysis in ultra high settings and must be beating his head by now.
14-11-2008, 10:42 AM
#21 (permalink)
ToTheBeatOfUrHeart
Q6600 proccy
2gb ram
Cheapest workable solution is CM EP 600 watt.
But maybe you would be on the lower side when overclocking with this one.
14-11-2008, 12:56 PM
#22 (permalink)
no way I am not that type of guy to sit and close my eye on my own request.
I was getting advises from friend in city and forums to which one gets better.
Sorry for not replying.....
Now to work.
I am thinking to
9800GTX or 9800GTX+
E7300 2.66 @ 1066 FSB
CM extreme 600W PSU
Today by 4pm from near PC market.
NOTE:- PLZ dont push me for HD4850 Coz its not easy to in pakistan.....Mostly out
of stock. But if I get it available I will buy it.
As for Alternates is there any similair to 9800 Gtx or 9800 Gtx+ in price.
thanks to all
bilal
SATA HDD-
14-11-2008, 01:11 PM
#23 (permalink)
Alter Bridge=GOD
BFG 9800GTX needs only ONE 6pin connector
Corsair 450 is the best PSU you can buy in that budget
Ditch CM 600 ..get Corsair with a lot more efficiency than any Cooler Master Extreme PSU
and no way is 450VX=Cooler MAster 600
in tests it delivered 500 + watts which it aint even rated for.
Apple Macbook Pro 17 :cool:
14-11-2008, 08:00 PM
#24 (permalink)
ANGEL OF DEATH
totally agree with him
| Dell 15z + WD 2TB | | Dell Studio 1555 + WD 1TB | | iPhone 4 32 GB | | Samsung Galaxy S2 White | | Good Desktop Power Of C2D + 4850 |
14-11-2008, 08:46 PM
#25 (permalink)
yeah me too agree but why not corsair 620 it could be handy.
asus g73jh lappy
14-11-2008, 08:58 PM
#26 (permalink)
Violent serenity.
Go for VX450W.
Much more power than required.
wrong.
o_0
Nope, CM EP 600W has more than enough power for it.
Thats the case with all Corsair PSUs. They are efficient and reliable. They always under-rate their PSUs.
