Old 09-11-2008, 04:43 PM   #1 (permalink)
Unhappy Ram issues
Recently brought 2x2GB Trancend ram,but the problem is it only shows 3GB ram.
Motherboard is MSI P45 NEO F.
So, I asked the assembler to come and check tomorrow.
What do you think, what is the problem? How can it be fixed.?
redmanc is offline
Old 09-11-2008, 04:46 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Ram issues
first check in BIOS.
if you are using 32-bit operating system, it can't show more than 3.5Gb
move to vista/xp 64bit.
desiibond is offline
Old 10-11-2008, 08:32 PM   #3 (permalink)
In, bios its showing 4096MB of ram.
Maybe its the OS prob.
Should I switch to vista ultimate 64 ?
redmanc is offline
Old 10-11-2008, 08:38 PM   #4 (permalink)
Bond, Desi Bond!
desiibond's Avatar
get either XP 64bit or Vista 64bit
Old 10-11-2008, 10:18 PM   #5 (permalink)
RMN
does 32bit Vista run comfortably with 4gb RAM?
DELL SP2008WFP|Cooler Master Elite 330 Cabinet|MSI P45 NEO-F|Intel Q6600|Palit HD 4850 Sonic|VISTAx64|Cooler Master PCAR-600|Transcend 2GB 800M|Creative SB LIVE!Ext.|Logitech Combo EX-90
RMN is offline
Old 10-11-2008, 10:20 PM   #6 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Dude. Am running Vista on a 2Gb ram and a 2yr old 2.3GHz single core processor.
your vista should run without a hiccup.
But, before you upgrade,run Vista upgrade advisor to check if your h/w has proper drivers for Vista.
By your siggy, it should be fine.
Vista 32-bit should run fine on 4gig ram but only 3.5gig will be recognized.
Old 10-11-2008, 10:26 PM   #7 (permalink)
RMN
oh crap....sry....i meant to ask abt 64bit!!!...sry my bad!
RMN is offline
Old 10-11-2008, 10:50 PM   #8 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Vista 64 bit should be able to run without any problem on 4gig ram.
Old 10-11-2008, 11:36 PM   #9 (permalink)
Krazy_About_Technology's Avatar
I think there is a switch that when added to the bootloader config enables using physical address extensions present on modern processors to enable access to ram beyond 32bit boundary. I dont remember exactly what was it. Google it.
Dell Inspiron 1525 - C2D 2 Ghz, 3GB, 250GB, X3100 :)
Samsung Omnia Pro B7610 with Stock WM 6.1 ROM
Blog: http://www.sumitbhardwaj.co.in/blog
Krazy_About_Technology is offline
OC Issues sam9s Hardware Q&A 173 13-10-2008 03:31 PM
old issues bhrth QnA (read only) 4 16-07-2006 04:48 PM
POP issues saurabh.sauron Software Q&A 4 18-05-2006 04:16 PM
PC issues icecoolz QnA (read only) 8 08-12-2004 12:19 PM
