Old 08-11-2008, 09:18 AM   #1 (permalink)
Exclamation Urgent Help needed!! PC restarting abruptly
Hi All,
My PC config is P4 3.0GHz HT, 2GB DDR 400MHz RAM, Nvidia GeForce 8400GS PCI Exp Graphics card, 2 x 80GB Samsung and 1 x 360GB Sata HDD.My power supply is Intex 400W. From yesterday,the PC boots fine but after say 3-4 mins after booting, it restarts abruptly.I tried this many times and i am thinking that this may be power supply issue..any answers to what may be wrong??And how can i check the PSU??
sohancool is offline
Old 08-11-2008, 09:22 AM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Urgent Help needed!! PC restarting abruptly
boot in safe mode and check Event Viewer for error messages.
desiibond is offline
Old 08-11-2008, 09:25 AM   #3 (permalink)
Ok..thanks for the quick reply
Old 08-11-2008, 10:17 AM   #4 (permalink)
~Beating Toughest Games~
pc_game_lover2004's Avatar
does it show a blue screen before restarting
PKG
My Rig :-Intel(R)Pentium(R)DualCPU E2160@1.80GHz, 2046MB RAM, 500 GB HDD, NVIDIA GeForce 8600 GT, Windows Vista™ Ultimate, Asus P5N-MX Motherboard
pc_game_lover2004 is offline
Old 08-11-2008, 10:29 AM   #5 (permalink)
No.. it boots properly,shows the windows desktop,loads startup programs and after 2-3 mins restarts suddenly..du u think this is a heating issue since my processor is a prescott?
Old 08-11-2008, 10:35 AM   #6 (permalink)
well i'm facing a similar problem too..check this out
Please Help Me Guys !!!
is ur prob. the same or diff.
PKG
Old 08-11-2008, 12:59 PM   #7 (permalink)
In my case no blue screen or anything appears..the PC just restarts..so i think its an overheating issue..will also chk out the HDD Health program u have mentioned in ur thread..
Old 08-11-2008, 01:03 PM   #8 (permalink)
Excessive happiness
furious_gamer's Avatar
Dude, this happens if the heat sink is not properly installed.. Otherwise due to RAM failure...
The last and most possible cause is PSU...U have a intex 400W PSU..rite... I hope there is the problem is...
Change the PSU(Just get ur friends 450 or 500W PSU and check) and see what happens...
If these all not fix ur pbm, then a fresh install of Windows XP may help u...
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Addicted to Game Dev & Grand Prix Story
furious_gamer is offline
Old 08-11-2008, 02:59 PM   #9 (permalink)
Thanks , will try a different SMPS and see..
Old 08-11-2008, 03:12 PM   #10 (permalink)
Violent serenity.
Psychosocial's Avatar
Change your sig... its not sluttering, its stuttering.... why I am telling this ? Google the word 'slut' ...
@OP
Have u OC'd ur PC ? If so tone it down. Try ur PC with a different SMPS or RAM. Or boot into safe mode and check for viruses.
Psychosocial is offline
Old 08-11-2008, 03:38 PM   #11 (permalink)
Excessive happiness
@KPower
thanks for correcting me...
BTW damn, how i forgot the word "slut"..
Old 08-11-2008, 04:51 PM   #12 (permalink)
No i have not overclocked my PC..will chk RAM also alongwith other PC components..do u think my 400W SMPS is enough? I also have 2 external 80GB HDD's which i have connected to the PC alongwith Sony DVD Writer..Pls suggest
Old 08-11-2008, 04:58 PM   #13 (permalink)
Excessive happiness
^^400W intex? thats not enough IMO..coz even my 7600GS need a 450W or higher to start working...
Before that i have a 400W PSU and my system restarts all in a sudden and after changing it to 500W PSU it works fine....
Old 08-11-2008, 05:15 PM   #14 (permalink)
Violent serenity.
for the 100th time.... I OC'd my 8800GT on a stock VIP 400W PSU and ran it stable 24x7 for 2 months till I got a new CM Ep500W.... and I didnt have any problems... then I dunno if 7600GS is a better card then mine .
Old 08-11-2008, 05:19 PM   #15 (permalink)
Excessive happiness
dude... do u compare the Zebronics 500W PSU with a Corsair VX450W PSU.. Not at all... I faced the problem and only i said that here...Since our area had a huge power fluctuation we need to get atleast 500W inorder to make it work...Why the same happen to the thread starter..Think so..
And not all PSU's are like VIP ones....(I dunno abt that PSU) but my intex 400W PSU refuse to work with my gfx card...
Old 08-11-2008, 05:39 PM   #16 (permalink)
Violent serenity.
^^FYI VIP PSU are not that good... about the same quality as Zebs...
Old 08-11-2008, 05:44 PM   #17 (permalink)
Excessive happiness
I cant argue with u anymore.... Just stop this here....
Lets try to help thread_starter....
Old 08-11-2008, 05:46 PM   #18 (permalink)
M3TAL H3AD M3
skippednote's Avatar
CM>Zebby>VIP
I spit Rainbows.
skippednote is offline
Old 08-11-2008, 05:49 PM   #19 (permalink)
Excessive happiness
Where the INTEX came in that list....
Old 08-11-2008, 07:00 PM   #20 (permalink)
Violent serenity.
Originally Posted by bassam904 View Post
CM>Zebby>VIP
+1
BTW, sorry for my foolishness on that 'bye-bye' thread... but you are also wrong somewhere. Sorry if you felt hurt .
Old 10-11-2008, 09:23 AM   #21 (permalink)
Hi guys, i have just checked the CPU core temperature in the Bios and its hovering around 85-86 degrees..is this normal??
Also i formatted the C: drive on which XPSP2 was installed and tried reinstalling it, but the Setup hangs when it starts detecting the Hardware(Around 36 min mark).Does this indicate some kind of hardware failure??
(P.S Also tried loading Vista SP1 but the setup hangs when all the System files are loaded(right after the Windows is loading system files... dialog appears and we go to the setup start after booting directly booting from the DVD)
Old 10-11-2008, 11:00 AM   #22 (permalink)
Fullbring
Zangetsu's Avatar
No..its not...check the Proccy fan & also the thermal paste applied.....its an overheating issue...
Windows OS Calculator Bug
Sqrt(9) - 3 = check the answer
Zangetsu is offline
Old 10-11-2008, 11:12 AM   #23 (permalink)
Ok.will take it to my dealer and get it checked..thanks all for ur suggestions
BTW how can we clean the processor heatsink?? I saw that a lot of dirt has accumulated over it..
Old 10-11-2008, 12:10 PM   #24 (permalink)
Bond, Desi Bond!
desiibond's Avatar
use a paintbrush (unused and clean).
Old 10-11-2008, 12:32 PM   #25 (permalink)
Great idea will definitely try it..
Old 10-11-2008, 12:51 PM   #26 (permalink)
Fullbring
Zangetsu's Avatar
lol u call it Gr8 idea..everybody here uses brush only 2 clean the dust..or vaccum cleaner(if available)
Zangetsu is offline
internet disconnects abruptly... Spiff Internet & WWW 3 30-06-2008 06:10 PM
Firefox 2.0.0.11 Hangs abruptly raksrules Internet & WWW 5 10-12-2007 11:40 AM
Restarting Windows Without Restarting Your BIOS (Vista or XP) marulez Technology News 14 23-08-2007 01:19 AM
system restarting, please help, urgent santu_29 Hardware Q&A 3 14-07-2006 06:53 PM
SYSTEM RESTARTS ABRUPTLY !!!!!!!!!!! freezer QnA (read only) 3 20-10-2005 01:13 PM
