Old 07-11-2008, 06:51 PM   #1 (permalink)
RMN
Default RAM Recommendation needed
i already have a Transcend 2gb stick of 800mhz.
i want to buy a single 2gb stick and which one do you recommend?
tq
DELL SP2008WFP|Cooler Master Elite 330 Cabinet|MSI P45 NEO-F|Intel Q6600|Palit HD 4850 Sonic|VISTAx64|Cooler Master PCAR-600|Transcend 2GB 800M|Creative SB LIVE!Ext.|Logitech Combo EX-90
RMN is offline
Old 07-11-2008, 06:55 PM   #2 (permalink)
Excessive happiness
furious_gamer's Avatar
Default Re: RAM Recommendation needed
Another Transcend 2GB 800MHz....
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Addicted to Game Dev & Grand Prix Story
furious_gamer is offline
Old 07-11-2008, 06:58 PM   #3 (permalink)
RMN
no im looking for another brand since memtest86 dint give me great results!
RMN is offline
Old 07-11-2008, 07:04 PM   #4 (permalink)
Excessive happiness
Kingston (Not the value series) or Corsair Dominator will give you what you want...
Old 07-11-2008, 07:06 PM   #5 (permalink)
RMN
hmmm...if i get 800mhz of any other brand...will i be able to use it as dual channel along with my transcend?
RMN is offline
Old 07-11-2008, 07:09 PM   #6 (permalink)
Excessive happiness
Ofcourse you are.. If ur Motherboard has the Dual Channel option...
Old 07-11-2008, 07:36 PM   #7 (permalink)
actually if you wanted to use dual channel.it is better if you get one from the same brand..with the same specifications
there is a reason why people buy in pairs..no hassle of matching
but @rmn didnt your memtest came up with several errors...and you might wanted to claim warranty on that..and using the existing one in dual channel when it has shown errors wont give good results at all..i think
Q6600 | p5n32e-sli | 2x1gb Kingston ddr2800 |2x250gb seagate hdd | sony dru-190A | creative sb audigy2 zs | xfx 8800gt | corsair hx-620 | antec 900 | Ms basic desktop 500 | logitech z2300 | apc 800va
realdan is offline
Old 07-11-2008, 08:27 PM   #8 (permalink)
M3TAL H3AD M3
skippednote's Avatar
Try Ocz or corsair ram's
I spit Rainbows.
skippednote is offline
Old 07-11-2008, 08:52 PM   #9 (permalink)
RMN
oh is OCZ a good brand?
@realdan
will i be able to get my RAM replaced?i mean how will i make them understand that its not working?
and which series from the foll brands shall i look for?(my primary use is multimedia development)
Kingston(Hyperx?)
OCZ(System Elite Series,Limited,Titanuim....etc)
Corsair(Dominator)
RMN is offline
Old 08-11-2008, 12:19 PM   #10 (permalink)
Excessive happiness
I suggest u to get the Corsair Dominator or OCZ Elite Series..
Old 08-11-2008, 12:34 PM   #11 (permalink)
RMN
im buying it of ITWares and this is what ive shortlisted.
OCZ Value Series 2GB Edition
or
G.SKILL DDR2 PC2 6400
how are these models?
these reason why im not looking for the higher series is because im not a heavy gamer...i use my system for Multimedia Development.
RMN is offline
Old 08-11-2008, 12:37 PM   #12 (permalink)
Excessive happiness
Then get the OCZ without any second thoughts.... This doesnt mean that G-SKILL is not good... Both were good and you select one of them....
Select OCZ....
Old 08-11-2008, 12:49 PM   #13 (permalink)
RMN
ok tnx!
and can i get a RAM replaced because memtest is showing bad results?
btw i thought of buying gskill because it has a heat spreader
RMN is offline
Old 08-11-2008, 12:53 PM   #14 (permalink)
Excessive happiness
Then its upto u....OCZ or G-SKILL..Both were good...
And no chance of getting replaced ur RAM unless its not in working condition or u have friend in that shop where u get that RAM....
Old 08-11-2008, 01:43 PM   #15 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
He's got a point
U'll get xtra 2GB 800MHz Tarnscend for Rs.1800 I guess.
http://pleaseguide.me/
comp@ddict is online now
Old 08-11-2008, 04:41 PM   #16 (permalink)
RMN
@comp
yes i know its good to have the same brand and model for dual channel but like i mentioned the transcend i bought came up with bad memtest results so i don't want to buy it again.
on more Q.
in case im having trouble using them as dual channel can i disable the feature while the RAMs are physically fixed as dual channel?
RMN is offline
Old 08-11-2008, 04:50 PM   #17 (permalink)
Excessive happiness
No u cant do so..U have to physically remove the RAM module in order to disable the dual channel mode...
Old 08-11-2008, 05:10 PM   #18 (permalink)
RMN
ah!
ok is transcend a reputed brand?does their RAMs often have complaints?
RMN is offline
Old 08-11-2008, 05:16 PM   #19 (permalink)
Excessive happiness
Its a reputed brand.. they only memory related products...So trust em dude...
AFAIK there is no such problems i heard of Transcend RAMs...
So try to replace the existing one and get 2 Transcend 2GB stick..or get two OCZ or G-SKILL 2GB sicks...
Old 08-11-2008, 05:21 PM   #20 (permalink)
RMN
yeah ill try calling them!
damn!
and tnx a lot btw!
RMN is offline
Old 08-11-2008, 05:23 PM   #21 (permalink)
Excessive happiness
Old 09-11-2008, 11:01 AM   #22 (permalink)
RMN
a little off topic...
i have 4 RAM slots on my mobo and i have only 1 2gb stick witch is fixed on the 1st slot....can i fix to any other slot....want to see if that solves my GFX issue.
RMN is offline
Old 09-11-2008, 11:17 AM   #23 (permalink)
Bond, Desi Bond!
desiibond's Avatar
First and foremost, you need to buy another RAM module with same timings as the Transcend one that you have and if you pair Transcend with OCZ or Corsair, Transcend will be a bottleneck. So, either get 2Gb Transcend or get a pair of 2gig corsair or ocz ram modules. You can then use 4gig corsair/ocz in dual channel pair and put transcend in the other channel or sell if off (only 64bit OS can recognize 4gig or more ram. 32-bit cannot access memory outside 3.5Gb)
desiibond is offline
Old 09-11-2008, 12:31 PM   #24 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Originally Posted by RMN View Post
@comp
on more Q.
There must be 4 DIMM slots in ur mobo. 2 pairs I must say
Put them in different pairs, that's all!
Old 09-11-2008, 02:18 PM   #25 (permalink)
RMN
tnx guys...
so anybody wants to buy my transcend??
and is it a must that i should have a stick on the DIMM1 slot?
RMN is offline
Old 09-11-2008, 03:04 PM   #26 (permalink)
Bond, Desi Bond!
desiibond's Avatar
^^ There are four slots on your mobo with same color for each pair. You need to insert RAM modules in same colored slots. Can be 1,2 or 3,4 or 1,3 or 2,4. Depends on motherboard.
Just check the color coding on your mobo. Mine's 1,2 or 3,4
Old 09-11-2008, 03:12 PM   #27 (permalink)
RMN
@desi
i meant when im using only 1 stick....my manual asks me to fix the RAM in DIMM1 when using only one stick...that's what ive done but since im having probs with my GFX card i just want to put the Single RAM in another slot...is that ok?
RMN is offline
Old 09-11-2008, 03:24 PM   #28 (permalink)
Bond, Desi Bond!
desiibond's Avatar
should be okay as long as it works
anyways, get rid of that module and get OCZ/Corsair 2x2Gb kit.
Old 09-11-2008, 04:24 PM   #29 (permalink)
RMN
get rid...but how?
i cant get that replaced right?
RMN is offline
Old 09-11-2008, 04:29 PM   #30 (permalink)
Bond, Desi Bond!
desiibond's Avatar
sell it. put it in bazaar section.
Recommendation on Mid-end 5.1 speakers RMN Audio 7 26-10-2008 08:34 AM
INTEL's recommendation comp@ddict Hardware Q&A 5 10-10-2008 10:37 PM
AGP recommendation gr8usr Hardware Q&A 5 16-12-2006 11:03 PM
