| Forum |
#1 (permalink) |
Things i need is I need a serial and a parallel port for programming microcontrollers. I need a firewire port for capturing video from my handycam biostar tp43-d2a7: > serial, parallel header only > No Firewire port nor header > Solid capacitors > 1600 MHz FSB without OC and support for 1066 MHz ddr2 ram without OC > Price 4000 (in pune) msi p43 neo-f > serial, parallel port > Firewire port or only header or none (both or any1 optional, confusion) ![]() > spdif-out internal connector > 1600 MHz FSB wit OC and support for 1066 MHz ddr2 ram with OC > Price 5450 (theitwares) Things i dont know and need clarification about are: 1) To use the headers on the mobo, i came to know that we can attach a bracket. How much will a bracket for serial port, parallel port, firewire port cost? 1.5) Can we get a single bracket having both serial and parallel port? 2) Does msi p43 neo-f come with ieee 1394a port or header only or none? They've put an 'Optional' logo on their site for these features. If i wanted that feature how much more can it cost? Anyone having a msi p43 neo-f or p45 neo-f board can confirm if they have this feature? 3) S/PDIF - where is it used generally? I'll be getting 2.1 AL or creative speakers which dont need it.
Dont be reluctant to do MenTaL work. |
#2 (permalink) |
I M A *STAR*
Go for biostar tp43-d2a7.
Regd ur first ques: U can get that bracket for very cheap. It will cost u arnd 200 Rs approx. But the main thing is it muust have header on mobo, then only. SO verify it first & then take ur decision. |
#3 (permalink) |
Excessive happiness
Get MSI P43 Neo F and seperately buy a bracket and attach with it...
AFAIK MSI is a solid Mobo and dunno abt BioStar ones....
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ Addicted to Game Dev & Grand Prix Story |
#4 (permalink) |
Well the review on insidehw (http://www.insidehw.com/Reviews/Moth...TP45D2_A7.html) was good. After searching more on the net i found just a couple of member posts saying they had some bios problems.
But the price and solid capacitors attracts me!
#5 (permalink) |
Excessive happiness
^^ Then, u r ready 2 face the pbms with that Mobo.. rite...
My wise option is MSI P43 Neo F ....
#6 (permalink) |
ok, after reading lots of user reviews on newegg about biostar tp43d2a7 and even their tp43hp i found out quite a lot of users complaining about the bios and also about ram not working even in 800mhz.
But checking the user reviews for msi p45 neo-f (could not find p43 neo-f on newegg) i saw a few users complaining about the board not being able to POST or not able to 'cold boot' and need a bios update just like the biostar mobo.
#7 (permalink) |
-bump?-
From the following - i'm not at all saying that i'm being stubbon about not wanting to go for msi p43 neo-f but just coz i found out newegg: Customer reviews for MSI P45 Neo-F are poor - 5 - 26% 4 - 35% 3 - 17% 2 - 9% 1 - 13% 5-6 (out of 23) customer reviews said that they had boot issues / 'cold start' issues / needed bios upgrades. Could someone having this board (p43/p45 neo-f) please share his/her experience? I also gave a thought to Asus P5K VM deciding to sacrifice pci-e 2.0. But on the asus site its written "* Please update the latest BIOS to support Intel 45nm CPU". Can anyone enlighten me on how to do this bios update?
#8 (permalink) |
Violent serenity.
lolumad? BioStar mobos are better than MSI ones. Biostar i45 has set a world record for OC'ing and staying stable at that OC. Solid capacitors are a great thing. Good if u hav hot conditions. I say go for BioStar.
Registered pwner of theists, noobs, posers and emos. |
#9 (permalink) |
15.0 GHz
Yeah go for Biostar.
My Friend with same mobo OC'D his Proccy from 2.2GHz To 3GHz...... Itz Good For OC'ing
PC(Intel Core2 Duo E4500 2.2GHz + Intel D946GZis + Dynet 2GB + 1GB DDR2 + 500GB WD Caviar + 250GB WD My Passport) iPod Touch 4th Generation - 64GB |
#12 (permalink) |
Bond, Desi Bond!
yep. But when you compare biostar P43 with Palit P35, I couldn't find much difference except that P35 support RAM till 800MHz but on the bright side "4-phase PWM with solid state capacitor to enhance stability and reliability" and crossfireX (won't push for cf anymore given the perf of X2 cards)
My first blogspace: http://desiibond.blogspot.com |
#13 (permalink) |
Violent serenity.
^^Ya, Palit P35A is the only <5k board to support Crossfire. I think that makes a better buy.
@OP, go for Palit P35A. Or if you can get your hands on BioStar i45, get that and send me one too
#14 (permalink) |
EXIT: DATA Junkyard
COmparing a P35 and P43, I shell in for P35
http://pleaseguide.me/ |
#15 (permalink) |
thanx for the replies and sry for my late reply - woke up late and then load shedding
@desiibond and kpower ya i had palit p35a also on my mind definitely. But i dont nee crossfirex really...not that much money. And if later i ever buy a new graphic card i'll be putting the current one into another comp. So i though later when i buy a new card it'll be a monster card which will need more bandwidth and so it'll need PCI-E 2.0 which p43 offers. Plus the biostar tp43 mobo is cheaper by ~500 than palit p35a. If at the last moment everything fails, i'll be going with palit. @desiibond what is meant by 4 phase PWM? on biostar tp43 review, there was a line "Nearby is located 4-pin P4 power connector under which is located 4-Phase power unit.". If thats the same thing u meant it would be gr8. @all Though biostar also has many negative feedbacks at newegg about bios, POST, ram etc (but overall less % than msi p43) i asked the vendor on phone about what he'll do to take care of these problems. He's said he can replace the board if any of those problems occurs during the 3 yrs warranty. So i've finally decided to go with it. @kpower biostar i45 is available here for ~Rs.7920(incl vat) and lynx-india has it for Rs.7786 - http://www.lynx-india.com/index.php?productID=3236
#16 (permalink) |
Violent serenity.
^^Thanks for the info. But I found that Abacus is the distributor in Mumbai and many of my relatives live there so I will get it from there
#18 (permalink) | |
Bond, Desi Bond!
#19 (permalink) |
Violent serenity.
^^BioStar i45 is a great board. I dunno how it compares with ASUS's P5Q Pro.. but BioStar has set a record for OC'ing and stability...
#20 (permalink) |
Bond, Desi Bond!
I take my word back dude. Just now I checked i45's specs and damn it, it's awesome. Go for it!!!!
sometimes, I need to look beyond asus and gigabyte
My first blogspace: http://desiibond.blogspot.com Last edited by desiibond; 08-11-2008 at 07:47 PM. Reason: Automerged Doublepost |
#22 (permalink) |
EXIT: DATA Junkyard
Well, u can stick for MSI P45 NEO-F @ 5.8k
That's the only P45 near ur budget. Then comes various P35 boards, which I recommend over a P43
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| biostar tp35d2-a7 vs msi p35 neo f | naveen572 | Hardware Q&A | 2 | 23-09-2008 10:31 PM |
| BIOSTAR or GIGABYTE? | mandeep_m91 | Hardware Q&A | 5 | 29-05-2008 11:35 PM |
| E8400 + Biostar GF7050V-M7 Benches | hellgate | Hardware Q&A | 9 | 02-04-2008 12:25 PM |
| Biostar or xfx. Urgent. | The Day Walker! | Hardware Q&A | 3 | 28-09-2007 06:56 PM |
