| Forum |
#1 (permalink) |
Call me Sumit
Can I connect a bigger (22" or 24") LCD monitor to my laptop and see movies or do some word editing while my laptop lid is open ? If yes then how ? Also will both the small 14" and 22" will be showing display when I do some word editing ? Rgds S |
#2 (permalink) |
Does yuour laptop have a VGA/DVI out? If so you can but please check that your graphics chip can support the resolution of the screen that you are planning to buy.
A dual monitor set up is fantastic - I have been using this for more than 5 years at home and at work [with a desktop] and will never go back to a single screen again.
Regards, Deepak www.rashminursinghome.com www.rashminursinghome.com/Albums |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| How to connect hard disk to external casing ? | King Arthur | Hardware Q&A | 4 | 14-09-2007 12:05 AM |
| Can i View TV with External TV Tuner Card & Monitor.....? Help needed | satyamy | Hardware Q&A | 2 | 02-07-2007 09:21 PM |
| can i connect ps2 to monitor? | mandar5 | Gamerz | 6 | 09-04-2007 07:18 PM |
| How to connect two monitor????? HELP PLEASE | stalin | Hardware Q&A | 1 | 22-03-2006 12:02 PM |
