| Forum |
#1 (permalink) |
my desktop power supply was damaged yesterday. so am unable to run it. i have some important files on my hdd which are required urgently. so is it possible to connect the desktop hdd to my laptop chipset sata slot for transfering the data. i have a 250gb hdd seagate sata which is to be connected to my laptop dell inspiron 1420. so will it work ? ? i need to transfer some files and so need to connect it for a small amount of time only. if it can be done, is it advisable to do so?? please reply urgently. thx. |
#2 (permalink) |
Dont know much but you can get an enclosure. Its about 600 bucks. I am using a Sata HDD in an enclosure via USB.
But I had to format it so that might not work. Why not connect it to a friends desktop and copy the data?
Regards, Deepak www.rashminursinghome.com www.rashminursinghome.com/Albums |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Desktop n Laptop Connecting | jeetumg | Laptops and Netbooks | 5 | 15-02-2007 08:14 PM |
| Connecting LAptop to Desktop using USB cable | kumarmohit | Hardware Q&A | 6 | 29-12-2006 12:36 AM |
| Problem Connecting a Laptop to a Desktop PC | drharrypotter | Laptops and Netbooks | 21 | 21-11-2005 09:47 AM |
| Connecting Laptop & Desktop | nedun_cheran | Laptops and Netbooks | 11 | 28-06-2005 11:04 PM |
| Connecting laptop hard-disk to desktop | sohummisra | Laptops and Netbooks | 8 | 31-03-2005 11:32 AM |
