| Forum |
#1 (permalink) |
I need to buy a External TV Tuner Card, within 1.5k Requirements:
C2Q Q6600 G0|ASUS Maximus Formula|XMS2 1GB x2|CM extreme Power 600W|CM Elite 332|WD 320GB HDD|Seagate 80GB HDD|SONY DVD+RW|Viewsonic VA1912wb 19"|XFX 7600GS|OCZ Vendetta 2|HP dv2601tx|Nokia N73 ME |
#2 (permalink) |
15.0 GHz
Recently I saw a Gemini USB TV Tuner....It cost's 1.6k...
I liked it as it was so compact and very easy to handle and specially for TV on laptop... It was just like Pen-Drive...
PC(Intel Core2 Duo E4500 2.2GHz + Intel D946GZis + Dynet 2GB + 1GB DDR2 + 500GB WD Caviar + 250GB WD My Passport) iPod Touch 4th Generation - 64GB |
#3 (permalink) |
Is that a good one, I want a reliable one.
#4 (permalink) |
Bond, Desi Bond!
^^ There is a Tech-Com external tuner card for 1.5k. superb VFM.
you can connect it using VGA.
My first blogspace: http://desiibond.blogspot.com Last edited by desiibond; 05-11-2008 at 04:30 PM. Reason: Automerged Doublepost |
#5 (permalink) |
Think Zen.
^I got one of those , for just watching tv occasionally. And yes its superb vfm.
I bought it as it only wanted to watch tv without any hassles , and it does the job perfectly. But i think i got it for less than 1.5k .
Do what you will; but not because you must. -- Zen Quote |
#6 (permalink) |
Can i know the model no. which u got. So that i can go in search of that here. Also does that support my Monitor Viewsonic VW1912wb. I have connected the DVI of monitor to the PC, and will connect the VGA of monitor if it supports.
#7 (permalink) |
Bond, Desi Bond!
the new one comes with lot of connectivity options so that you can connect it to STB and to good old cable
My first blogspace: http://desiibond.blogspot.com |
#8 (permalink) |
Can i know what is STB, can you explain about that. By the way which model of Tech-Com should i buy.
#9 (permalink) |
Bond, Desi Bond!
Set Top Box
Dish tv , tata sky .... http://www.techcomindia.com/home.php...al&prodid=726# above model is USB card
My first blogspace: http://desiibond.blogspot.com Last edited by desiibond; 06-11-2008 at 04:52 PM. Reason: Automerged Doublepost |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Re: Tv Tuner | harmads | QnA (read only) | 6 | 26-06-2008 06:08 AM |
| tv tuner with lcd..??? | deepinder_mann1988 | TVs / Monitors | 1 | 27-03-2007 11:27 PM |
| TV TUNER | Polter | Hardware Q&A | 1 | 14-12-2005 11:17 AM |
| tv tuner help | shaunak | QnA (read only) | 4 | 03-05-2005 10:45 PM |
