| Forum |
#1 (permalink) |
Ankit
processor - AMD64 2800+ MotherBoard- Ausus K8S MX Ram - 1GB x 2 DDR1 Harddisk- samsung 160 gb 7200 rpm wd 160 gb 7200 rpm Graphic Card- biostar geforce 6200 256 mb I want a pc for only for Hardcore gaming plz suggest me a new n latest gaming dat should last for 2-3 yrs atleast PC configuration my budget is 30,000-35,000 rs I want Processor how is Intel core 2 Q8200 for gaming does it have overclockin feature MOtherBOard dat support TWO grapic card & HAS overclockin feature , DDR3 Ram, Graphic Card & how is Palit 9600 GT 1GB SONIC will it run all games lik crysis Is DDR3 Ram Better Than DDR2 Ram's.... |
#2 (permalink) |
Violent serenity.
^^Ya, you are saying that you want to buy a Ferrari in the budget of a Maruti ? No offence but you Q8200, SLi/XFire mobo and DDR3 RAM all in the budget of 35k 0_o.
1st :- Core 2 duos are better 2nd :- Stay away from AMD right now 3rd :- DDR3 does perform better than DDR2 but performance increment is little so dont buy it. Go for :- E7200 MSI P45 Neo-F 1x2GB DDR2 800MHz RAM Palit HD4850 512MB GDDR3 CM EP500W PSU Zebronics Bijli cabinet Dell 198WFP 19" LCD Samsung SH-203B optical drive WD Caviar SE16 640GB HDD Logitech Gaming G1 desktop kbd/mouse Altec Lansing BXR1121 2.1 speakers
Registered pwner of theists, noobs, posers and emos. |
#3 (permalink) |
Ankit
dude ur rt bt i only need is CPU only CPU i don't want 2 buy Monitor, speakrs n keyboard n mouse i have it all i want 2 have a powerfull gamin system under a budget of 35,000 rs which i can upgrade with moer than one graphic card's n lot's of ram the motherboard should have crossfire facility...n latest
#4 (permalink) |
Bond, Desi Bond!
now, you need to buy processor, mobo, ram and Graphics card
Processor: E8400 for 8.5k RAM: Corsair TWIN2X4096-6400C5 (2 X 2GB DDR2 800MhZ C5) kit for 5k mobo: ASUS P5Q Pro for CF setup 8k or MSI P45 Neo-F for 5.5k (no CF) GPU: Palit HD4870 for 17k or two HD4850's in Crossfire mode for 19k Choice is yours
My first blogspace: http://desiibond.blogspot.com |
#5 (permalink) |
Ankit
i wanna buy a CPU with Processor, mobo,Graphic card, Ram DDR3 or DDR2 , SMPS.
in which i can add more ram n gpu . currently my budget is 35,000 rs after 3 or 6 mnths i can upgrade it wid 30,000 more to my pc coz my current pc i creating 2 much prob nw i don't wanna take any risk u all guy's a havin very gud knowledge abt comp so plz hlp me out 2 hav a gud gamin machine or i shld wait for Core i7 Last edited by detonator2359; 07-11-2008 at 11:58 AM. |
#6 (permalink) |
Bond, Desi Bond!
E8400 8.5k
Transcend/kingston 2x2Gb DDR2800 ram 3.5k MSI P45 Neo-F 5.5k HD4850 9.5k Cooler master RS500-PCARA3 500W : 2.5k you won't be able to get i7 for 35k. 2Gb DDR3 price is around 5k. you may not need CF board int he future as X2 single slot cards from ATI are showing lot of promise, removing the need for CF setup HD4850 X2 single slot dual GPU card kicking GTX280 E8400 easily beats Q8200 in gaming.
#7 (permalink) |
Ankit
will it run all heavy graphic games...n won't crash before 2-3 yr's in b/w i'll b upgradin it....
how is ATI RADEON HD4870 GPU Vs GTX 260 HOW IS OVERCLOCKIN....???? PROCESSOR, MOBO, GPU, RAM
Last edited by detonator2359; 07-11-2008 at 12:06 PM. Reason: Automerged Doublepost |
#8 (permalink) |
Violent serenity.
^^GTX260 vs HD4870 ??
HD4870 kicks GTX260 in the buttt. Ok, I say you go for :- E8400 P5Q Pro 2x2GB DDR2 800MHz Transcend RAM Palit HD4870 1GB
#9 (permalink) |
Ankit
N For Hw Much They R Costing...????
N Which Cabinet I Should Get -cooler Master I Can't Put More Than 35000 Rs At Once But I Can Upgrade My Pc Wid More Than 10,000 Rs In Every 2 Mnths....???? Last edited by detonator2359; 07-11-2008 at 12:20 PM. Reason: Automerged Doublepost |
#11 (permalink) |
Violent serenity.
^Which card u getting ? If its a <9k card then I would say XP coz u wont get good FPS in Vista where the newer games play on DX10... but if ur going for card costing more than 9k, stick to Vista and you wiill get great FPS.
#13 (permalink) |
Violent serenity.
^^ROFL... use Vista.. Vista ftw...
I thought u were asking that bcoz u were getting lame FPSes on Vista coz u were using a low end. Anyways, happy gaming HD4870 is a great card BTW, nice purchase dude. Congo ! How much dough did u pay for it ?
Registered pwner of theists, noobs, posers and emos. Last edited by Psychosocial; 10-11-2008 at 12:09 AM. Reason: Automerged Doublepost |
#15 (permalink) |
Violent serenity.
35k dude ?
Get this if you can :- Intel Core 2 Duo E8500 BioStar TPower i45 board 2x2GB Corsair 1066MHz RAM
#17 (permalink) |
Violent serenity.
Overclocking means to increase a processor's speed but that will make it hot and also resulting in lesser product life... do it at ur own risk !!
Yup, all processor's OCable ... it actually depends on a mobo as to how well you can OC and the mobo I have suggested has set a record for OC'ing and stability. Wether u need crossfire or not is upto you... Crossfire = two, three or 4 ATi cards working together. Its upto you to choose. If you need crossfire then u will have to change the mobo too. If u choose to go for Crossfire, get the ASUS P5Q Pro board. i7 are a nice set of proccys... but in gaming, they are the same as Quads... otherwise they are blazingly fast. And ya, Quads fail in front of Core 2 Duos in gaming.... so stick with E8500 as of now..
Registered pwner of theists, noobs, posers and emos. Last edited by Psychosocial; 10-11-2008 at 12:44 AM. Reason: Automerged Doublepost |
#19 (permalink) |
Violent serenity.
Budget ?
If its high, then go for Cooler Master CM690 (4k) and Corsair HX620W (6-6.5k). If low, then go for Zebronics Bijli cabinet (1.5k) and Corsair HX620W (6k-6.5k) w/ever u do, get the HX620W...
#20 (permalink) |
Ankit
6 k for cabinet and smps
n for how much rs i should get palit hd4870 sonic 1 gb Last edited by detonator2359; 10-11-2008 at 01:09 AM. Reason: Automerged Doublepost |
#21 (permalink) |
Violent serenity.
^^Atmost 19k... dunno the exact price. 512MB version is @18k so 1GB will be 19 or 20k....
Damn.. for 6k, pick up the Zebronics Bijli cabinet and Corsair HX520W... best combo u can get for that price which can handle ur rig
Registered pwner of theists, noobs, posers and emos. Last edited by Psychosocial; 10-11-2008 at 01:26 AM. Reason: Automerged Doublepost |
#22 (permalink) |
Ankit
THANKX Bro
u know any online site frm which i can place my order...????? can u give me any idea abt the cost of parts u have suggested...???? n for how much i should sell my old pc Last edited by detonator2359; 10-11-2008 at 01:41 AM. Reason: Automerged Doublepost |
#23 (permalink) |
DELL SP2008WFP|Cooler Master Elite 330 Cabinet|MSI P45 NEO-F|Intel Q6600|Palit HD 4850 Sonic|VISTAx64|Cooler Master PCAR-600|Transcend 2GB 800M|Creative SB LIVE!Ext.|Logitech Combo EX-90 |
#24 (permalink) |
Ankit
WHAT ARE THE COST OF THESE PARTS
Processor:CORE 2 DUO E8500 MOtherBOard:ASUS P5Q PRO OR BIOSTAR TPower i45 board RAM:2x2GB Corsair 1066MHz RAM OR For How MUCH SHOULD I GET THESE PART'S |
#25 (permalink) |
Bond, Desi Bond!
E8500: 9.5k
P5Q Pro: 8.5k-9k Biostar i45: 7k I think Corsair TWIN2X4096-8500C5D (2 X 2GB DDR2 1066MhZ): 10k totally unworthy Get this one instead: Corsair TWIN2X4096-6400C4DHX (2 X 2GB DDR2 800MhZ C4): 6k-6.4k
#26 (permalink) |
dude check those prices on the sites i mentioned...they have good prices.
#27 (permalink) |
Ankit
THAnx Dude....
which mobo is better ASUS P5Q PRO OR BIOSTAR TPower 45i i need overclocking support n is there a need of crossfire in future again confused with graphic card Palit HD 4870 Dual Sonic 1GB DDR5 256Bit Dual Slot Cooler or else i should go for which gaphic card under 15k Last edited by detonator2359; 10-11-2008 at 08:46 PM. Reason: Automerged Doublepost |
#28 (permalink) |
Violent serenity.
If crossfire then P5Q Pro and if OC'ong then i45....
#29 (permalink) |
so far ive hear the 4850 and 4870 are the best in their own class..
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| New Gamin PC [Very tight on budget] | atish | Hardware Q&A | 30 | 10-06-2008 03:03 PM |
| new gamin PC config | buddystar | PC Components / Configurations | 10 | 21-04-2008 12:50 PM |
| Please RATE my blog !!.. Suggestions required ! | akshaykapoor_3 | QnA (read only) | 6 | 23-07-2007 05:26 PM |
| refresh rate of monitor.please help.your suggestions required. | quan chi | Hardware Q&A | 13 | 05-05-2007 03:13 AM |
| wanna buy a gamin pc | anshumanarora | QnA (read only) | 17 | 26-06-2005 02:00 AM |
