Old 05-11-2008, 05:19 AM   #1 (permalink)
Still learning...
He28's Avatar
Exclamation Mainboard & HDD.
Hi all.
Please help me to find out which motherboard I am using. Is there any way or utility to find out which mainboard I am using in my Acer macine?
Its a second hand PC and I have no manuals/information about hardware. All I know is, it has P4 3.06 GHz with 512 MB RAM. 120GB SATA HDD.
I wish to know about mainboard and what is the maximum size of HDD it can accept. I am planning to buy a 250 GB drive. I am not sure if it will be accepted without any comaptibility issues.
Aplogies if it is repost.
Thank you for time.
People laugh at me because I am different...,
I laugh at them because they all are the same...
This is... attitude!
He28 is offline
Old 06-11-2008, 11:07 AM   #2 (permalink)
Still learning...
He28's Avatar
Default Re: Mainboard & HDD.
No body helping...
Is there no way to find what maximum size of HHD my system can accept?
He28 is offline
Old 06-11-2008, 11:15 AM   #3 (permalink)
No pain....No gain
john_the_ultimate's Avatar
Use everest http://www.lavalys.com/products/down...?ps=UE&lang=en
john_the_ultimate is offline
Old 07-11-2008, 06:58 AM   #4 (permalink)
Still learning...
He28's Avatar
john_the_ultimate, thanks buddy.
I will try this and let you know. Will this application help me to find the maximum HDD size my system can accept?
He28 is offline
Old 07-11-2008, 07:48 AM   #5 (permalink)
Bond, Desi Bond!
desiibond's Avatar
motherboard model number should flash during boot at POST (black background with grey text)
desiibond is offline
Old 07-11-2008, 08:25 AM   #6 (permalink)
Still learning...
He28's Avatar
Hi desiibond...
How is E6 thread going on??
How will I be able to find the max size of HDD for my system?
Thanks
He28 is offline
Old 07-11-2008, 08:52 AM   #7 (permalink)
Bond, Desi Bond!
desiibond's Avatar
E6 thread??
current systems support huge size of HDD's, say it will be in terabytes.
post your mobo model number first.
Old 07-11-2008, 08:56 AM   #8 (permalink)
paroh's Avatar
i think it will support hard disk as ur computer have sata support. If there is a little dout u can buy ultra ata card. if u thinking of buying sata hard disk so go for ata card that supports sata other wise purchase ata card supporting ide
Note: U buy hard disk 99% it will work and for other 1% u can buy Ultra ata card later on. Card is cheap around Rs.600-700
paroh is offline
Old 07-11-2008, 11:52 PM   #9 (permalink)
Still learning...
He28's Avatar
Smile Re: Mainboard & HDD.
Hi all.
Thanks for your help.
Here is the data. I hope this is all info you need to help me.
Thanks again.
Motherboard Properties:
Motherboard ID = 09/26/2006-P4M800Pro-823-6A7L6M4AC-00
Motherboard Name = MSI PM8M3-V / PM8PM-IL
CPU Type = Intel Pentium 4 524, 3066 MHz (23 x 133)
Motherboard Chipset = VIA CN700 / P4M800 CE / P4M800 Pro / VN800
Front Side Bus Properties:
Bus Type Intel GTL+
Bus Width 64-bit
Real Clock 133 MHz (QDR)
Effective Clock 533 MHz
Bandwidth 4266 MB/s
Memory Bus Properties:
Bus Type DDR2 SDRAM
Bus Width 64-bit
DRAM:FSB Ratio 8:4
Real Clock 267 MHz (DDR)
Chipset Bus Properties:
Bus Type VIA V-Link
Bus Width 8-bit
Real Clock 67 MHz (ODR)
Bandwidth 533 MB/s
Motherboard Manufacturer:
Company Name Micro-Star Int'l Co.,Ltd.
Product Information http://global.msi.com.tw/index.php?f...=1&cat2_no=170
BIOS Download http://global.msi.com.tw/index.php?func=downloadindex
BIOS Properties:
Vendor = Phoenix Technologies, LTD
Version = 6.00 PG
Release Date = 09/26/2006
Size = 512 KB
Boot Devices = Floppy Disk, Hard Disk, CD-ROM, ATAPI ZIP, LS-120
Capabilities = Flash BIOS, Shadow BIOS, Selectable Boot, EDD, BBS
Supported Standards = DMI, APM, ACPI, PnP
Expansion Capabilities = ISA, PCI, AGP, USB
He28 is offline
Old 08-11-2008, 08:43 AM   #10 (permalink)
Bond, Desi Bond!
desiibond's Avatar
^^ you can use any HDD that is currently available in the market but you need to have Vista or XP with SP2 installed.
Old 11-11-2008, 04:06 PM   #11 (permalink)
Still learning...
He28's Avatar
Thanks desiibond
So you mean to say I can add a 250 GB SATA without any issues? So, why SP2 is needed for XP?
I will be really thankful if you can explain the use of SP2 for HDD compatibility. And is there any restriction for size of active partition?
Thanks.
He28 is offline
Old 11-11-2008, 04:18 PM   #12 (permalink)
Fullbring
Zangetsu's Avatar
SP2 has many features....such as enhanced security,upgraded version of system drivers,bug fixes in XP initial version...etc
There is no question of SP2 4 HDD compatibility
Windows OS Calculator Bug
Sqrt(9) - 3 = check the answer
Zangetsu is offline
Old 25-11-2008, 12:28 PM   #13 (permalink)
Still learning...
He28's Avatar
Red face Re: Mainboard & HDD.
Thank you guys.
One last question....
Is it possible to find from above data how many SATA can be connected. If I am correct the boards usually support 4 parallel HDDs.
How many SATAs my mainboard can take.
Sorry, if I am bugging you with stupid questions.... I am 'Still Learning'.
Thanks again.
He28 is offline
Old 25-11-2008, 01:20 PM   #14 (permalink)
Caballero de Real Madrid
m-jeri's Avatar
Open the Cabby..check how many SATA ports in ur mobo... and look how many power cables left..
then calculate the no of HDD's that could be plugged...
Or get a HDD dock..so that single USB port and any no of HDD..just use it like OLD 8 bit video game catridges
Or use External cases...get a USB multiplier...
|PC-15R-i3 M530|3GB DDR3|320GB|5470 512MB|500 GB Ext|D/L-D410PT|1GB|500GB|E122|APEX MI - 100|A/V-E2200HD|PS3 80GB+AT90USB162|Z5500 D|10TB|MOMO Wheel|APC 1KV|Click-500D|18-55 IS|
m-jeri is offline
Old 26-11-2008, 10:48 AM   #15 (permalink)
Still learning...
He28's Avatar
Originally Posted by m-jeri View Post
Open the Cabby..check how many SATA ports in ur mobo... and look how many power cables left....
I checked... it has only 1 SATA port (red one)...
Is there any cable available that can accept 2 SATAs the way we use to connect old HDDs??
What's HDD dock? I am sorry again I am asking stupid questions.
Thanks you help.
He28 is offline
Old 28-11-2008, 06:57 AM   #16 (permalink)
Still learning...
He28's Avatar
No help...??
He28 is offline
World’s First Mainboard with Open-Source BIOS thunderbird.117 Open Source 2 26-02-2007 12:59 PM
MSI RS482m4 ILD mainboard & bluetooth ? reddragon Hardware Q&A 2 23-10-2006 03:58 PM
Dual monitors with gigabyte 8VM533M-RZ mainboard Aanand QnA (read only) 4 30-08-2006 09:40 AM
can LCD Monitor needs different port for plug in mainboard ? myhotdog Hardware Q&A 6 02-04-2006 11:08 PM
what is TVout in a MainBoard ? reddragon Hardware Q&A 1 03-03-2006 08:39 PM
