Old 04-11-2008, 09:04 PM   #1 (permalink)
Default Need a suggestion for Using RAM
HI, Pals,
I have a desktop Pc, with fallowing config
512MB ram
mobo 915GAV Intel desktop.
so, my question is that, can I use a 256MB RAM along with this 512MB chip,
if i use , will i get any sort of problems??? please suggest me,My system performace is declined so for boosting it up, i purchased a 256MB chip.
sravan.boom is offline
Old 04-11-2008, 09:21 PM   #2 (permalink)
AMD & ATI FANBOY
ultimategpu's Avatar
Default Re: Need a suggestion for Using RAM
dude ,, u can add 256MB ram ,, sure it ll no give u any problem --------> go ahead
GAMING RIG=>C2DE8500 | ASUS P5Q PRO |3GB DDR 800 |VIEWSONIC VX1932WM|CM 600 WATTS |PALIT 4850
PC RIG=>AMD PHENOM X4 9550 | ASUS MOBO |2GB DDR 667 |CORSAIR 450 WATTS |17"TFT LG |2 TB SEAGATE
ultimategpu is offline
Old 05-11-2008, 05:43 AM   #3 (permalink)
Fast 'N' Furious
topgear's Avatar
U can use 256MB ram but I will recommend you to add another 512mb ram instead of
256mb.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Suggestion Box Raaabo Feedback 711 27-04-2012 04:07 PM
Need suggestion tuluvaguy QnA (read only) 35 22-09-2008 10:23 PM
Suggestion To Buy bal1961 Hardware Q&A 7 21-12-2007 11:45 PM
New CPU... suggestion gsoul2soul Hardware Q&A 5 07-10-2006 11:14 AM
some suggestion Dark Star Hardware Q&A 4 04-05-2006 06:44 PM
