04-11-2008, 12:24 PM
Need A Low Cost PC...
Hi Everyone,
I want to buy a secondary PC for myself. I already have a PC to fulfill my gaming needs. I need this PC for a little bit of casual gaming, watching movies and doing some project work (like in JAVA, C, C++). Could you please help me out with this one. Coz somehow i find making high end rigs much easier than low end one's!! My budget is Rs. 25000 max. Please Help!
04-11-2008, 12:53 PM
Excessive happiness
Re: Need A Low Cost PC...
E2180 - 3.4k
ASUS P5K PL VM or P5K PL CM - 2.7k
2GB DDR2 - 1.8k
ViewSonic 19" - 8.8k
Zebronics Cabinet - 1.2k
Logitech Combo - 0.9k
Samsung DVD RW - 1.1k
Altec Lansing BXR 2.1 Speakers - 1.2k
WD 160GB - 2k
Total 23.3k
Edited : According to the suggestion by IronManForever.....
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
04-11-2008, 01:50 PM
Perhaps you can change the proccy+mobo comb to AMD 4600+ (2.85k) or 5200+ (3.6k) with ASUS M2A-VM (3.9k)... And you forgot HDD... 160 GB will cost 2k... Since this is a low end system, I think the Powersafe SMPS will be overkill... The default SMPS shipped with the cabinet should suffice... And maybe 9500GT will be better than 8600GT
04-11-2008, 02:29 PM
Excessive happiness
^^ Does the mobo suggested by u has onboard IGP?
BTW 8600GT is just my additional suggn... If he wish he buy that... If he buy the gfx card only he needs PowerSafe PSU... Else the default PSU with the cabby do good...
and save a lot of money too....
PS Request
04-11-2008, 02:33 PM
IronMan; Ready to Roll...
I do NOT think the above implies for a dedicated graphics card when one HAS a powerful PC already.
Aluminum MacBook 2.0GHz Collector's Edition
Windows Box: 2.26G P4, 1GiB RAM, 320GB SATA + 80GB PATA HDD, Nvidia FX5200
AOC Fovi F22
iPod Touch 16GiB, HTC Gene, Moto W230, Sansa Express
04-11-2008, 03:55 PM
The M2A-MX has very decent onboard graphics through the use of the AMD690V chipset (ATI Radeon X1200 Graphics)... So, unless the comp is used for modern games, there may not be need to buy Graphics card even... That will shave off about 4-5k in the cost...
Arun
04-11-2008, 04:12 PM
EXIT: DATA Junkyard
But I wud suggest an AMD config with HD3200 as onboard solution which is powerful, and reliable, and finally u can get the rig for lesser than what u went out to spend.
04-11-2008, 06:50 PM
^^ Yes, I think that is a good option... Gigabyte's GA-MA78GM-S2H comes with 780G chipset with HD3200 graphics and costs only 4.7k... You can cancel the graphics card and save it for the future...
ASUS's M3A78-EMH HDMI costs 5.8k...
Arun
05-11-2008, 12:15 AM
^^ My post was for rajkumar_pb's configuration which had a GFX card. And instead of a 17 incher, adding 1 k could get OP a 19 incher monitor.
AOC Fovi F22
05-11-2008, 05:05 PM
EXIT: DATA Junkyard
See here:
X2 4600+ @ 2.7k
Jetway 780G @ 4.2k
2*1GB DDR2 800Mhz RAM @ 2k
Logitech kbd/mouse combo @ 0.7k
(u said u hav another GOOD rig so) Logitech R-10 @ 0.4k
ViewSonic 1928w 19" @ 8.2k
iBall i612 Cabinet with 400W PSU @ 1.2k
Total - 19.4k
Now if you want, you can add one of these:
8600GT 256MB DDR3 @ 3k
Zotac 9500GT 512MB DDR3 @ 4k
HD4650 @ 4.8k
HD4670 @ 5.4k
And all are within 25k, and ^^ cards will work with the 400W PSU with cabinet.
06-11-2008, 04:20 AM
Hi
I am from stech we provide new and used com at very low price
u can buy a pc(new) for Rs22000 with following config
Mercury PNMCP73V Designed for latest Intel Core 2 Quad/ Core 2 Duo(motherboard)
intel dual core e2180@ 2.00GHz (processor)
1gb ddr2 ram
nvidiaGeForce 7 Series Graphics Processing Unit
17" lcd monitor LG
perx black shine cabinet with smps
160gb sata segate harddisc
wireless keyboardmouse logitech
dvd writer LG
if intrested pls contact 9868277592 baltejgandhi
price can be compromised
06-11-2008, 12:52 PM
Excessive happiness
@baltejgandhi
Would u plz post the individual prices....
BTW who needs a 7 series GPU when 8 series available at damn cheap price...
PS Request
^^ That config sucks in front of what rajkumar_pb's suggested. Where is speaker set? Mercury makes el-yucko! mobos.  Samsung DVD writer SH-203B or something like that is one of the best out there. And the tray is very nice. Using it since 6 months.
And 17 inch LCD is so-so in comparision of 19" which comes at just a few bucks more.
AOC Fovi F22
06-11-2008, 12:54 PM
Excessive happiness
Of course dude....
PS Request
06-11-2008, 03:55 PM
EXIT: DATA Junkyard
Originally Posted by baltejgandhi
Hi
1gb ddr2 ram
17" lcd monitor LG
dvd writer LG
Aate hi shuru guru!
07-11-2008, 04:25 PM
Originally Posted by rajkumar_pb
E2180 - 3.4k
2GB DDR2 - 1.8k
WD 160GB - 2k
Total 23.3k
Sorry I went missing after my first post. I liked this config. But could you please suggest a low cost efficient graphics card to fit into my budget...
07-11-2008, 04:31 PM
Excessive happiness
Hmm.. Yeah i give some options... Assume ur in tight budget and suggest u a card priced b/w 1.5k - 2.5k
XFX 7300GT - 2.2k ...(This one is 256MB DDR2)
MSI 8400GS - 1.9k..(512MB DDR2)
MSI 8500GT - 2.5k
I prefer MSI8600GT 256MB DDR3 for 3k.....
PS Request
10-11-2008, 05:01 PM
EXIT: DATA Junkyard
8600gt^^^+100
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
what is the cost
debojyoti |
Software Q&A |
1 |
06-09-2007 10:17 PM |
cost of 1gb ram?
sidcool |
Hardware Q&A |
15 |
20-11-2006 12:19 PM |
Cost of 300 GB HD?
a_medico |
Hardware Q&A |
3 |
18-01-2006 12:51 PM |
Cost
Trinity |
QnA (read only) |
1 |
13-06-2005 08:11 PM |
