Old 04-11-2008, 11:53 AM   #1 (permalink)
India rocks
amc888's Avatar
Default Suggest an internal TV Tuner Card
Friends,
I want to buy an internal tv tuner card for connecting Tata Sky to My PC. My budget is 1K. Please suggest some good models........
amc888 is offline
Old 04-11-2008, 12:02 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Suggest an internal TV Tuner Card
^^ I am thinking of selling my 2yr old Pinnacle PCTV 110i.
http://www.pinnaclesys.com/PublicSit.../PCTV+110i.htm
location bangalore and 700 bucks.
desiibond is offline
Old 04-11-2008, 12:11 PM   #3 (permalink)
India rocks
amc888's Avatar
Sorry Friend, I am thinking to buy a new one.
amc888 is offline
Old 04-11-2008, 12:19 PM   #4 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Okay. I think you can check Tech-Com Internal TV Tuner card.
Old 04-11-2008, 12:42 PM   #5 (permalink)
15.0 GHz
VarDOS's Avatar
PixelView is good...
I am using PixelView TV TunerCard to connect DishTV to my PC.
VarDOS is offline
Internal TV Tuner Card gkiran Reviews 27 09-11-2008 04:59 PM
Internal or external TV Tuner Card? Yogesh Sarkar Hardware Q&A 12 05-10-2008 03:20 PM
internal tv tuner card reddevil2 Hardware Q&A 1 13-12-2005 10:40 PM
