Old 03-11-2008, 11:13 PM   #1 (permalink)
AMD & ATI FANBOY
ultimategpu's Avatar
Unhappy viewsonic VX1932WM "newly bought need some advice"
guys need help
i bought
viewsonic vx1932wm monitor ,,,, i heared that monitor has RTC error what is that rtc ,, what it does ... i saw only one error while playing games the color is resembling something like ,, but i saw very superb response time ,, the game is running ultimately fast
GAMING RIG=>C2DE8500 | ASUS P5Q PRO |3GB DDR 800 |VIEWSONIC VX1932WM|CM 600 WATTS |PALIT 4850
PC RIG=>AMD PHENOM X4 9550 | ASUS MOBO |2GB DDR 667 |CORSAIR 450 WATTS |17"TFT LG |2 TB SEAGATE
ultimategpu is offline
Old 05-11-2008, 10:03 AM   #2 (permalink)
Query Killer!!!!!!
max_snyper's Avatar
Default Re: viewsonic VX1932WM "newly bought need some advice"
I Think This Is what U Should Check Out For RTC Error.....
http://www.xbitlabs.com/articles/mon...methods_6.html
max_snyper is offline
Old 05-11-2008, 12:07 PM   #3 (permalink)
Violent serenity.
Psychosocial's Avatar
Do one thing :-
Plug it out. Take a sledgehammer and some bombs. Hit it with a sledgehammer and when it breaks, put the bombs inside and blast. If anyhting is left, sit on it and you will get SOME errors.
Really, you are worried bcoz your hardware is not corrupt/bad.... ROFLMAO
Psychosocial is offline
Old 05-11-2008, 10:56 PM   #4 (permalink)
@ ultimategpu
can you please post a good review with pics.
It would be highly appreciated.
Thanks
wishmaster.dj is offline
Samsung 19"W Vs Viewsonic 20" W TFT Monitors blacklight Hardware Q&A 12 22-05-2007 07:27 PM
The "Earphone and Headphone Buying Advice" Thread insanekiller Audio 14 22-05-2007 03:08 PM
The "Portable Media Player Buying Advice" Thread insanekiller Hardware Q&A 19 17-05-2007 01:44 PM
"We Are Not Alone!" Newly Found Earth-like Planet May Have Life! Third Eye Random News 3 27-04-2007 01:57 PM
Viewsonic announces "1ms" Response Time LCDs jamyang312 Technology News 1 09-02-2006 07:38 PM
