03-11-2008, 11:03 PM
Very Strange!
I recently upgraded my pc to
MB:Asus M2N MX SE PLUS
Proc:AMD 2X 5200+
and added 2x1 gb DDR2 RAM
The problem is when I put both the ram in, there is no display. When I used each ram individually, they work fine.
Any help?
www.harivarrier.com
Check out to earn money...
03-11-2008, 11:17 PM
AMD & ATI FANBOY
Re: Very Strange!
is that 2 RAMS are same mhz ,, like same are 667 or 800 mhz,,,
GAMING RIG=>C2DE8500 | ASUS P5Q PRO |3GB DDR 800 |VIEWSONIC VX1932WM|CM 600 WATTS |PALIT 4850
PC RIG=>AMD PHENOM X4 9550 | ASUS MOBO |2GB DDR 667 |CORSAIR 450 WATTS |17"TFT LG |2 TB SEAGATE
04-11-2008, 01:26 AM
Re: Very Strange!
yes everything is the same. I Updated the BIOS too but no go
www.harivarrier.com
04-11-2008, 02:45 AM
IronMan; Ready to Roll...
Re: Very Strange!
Even if two RAMs are different, it shouldnt be a problem.. The higher speed module will throttle itself.
Try different combinations of RAM slots.. How many do you have 2/4?
Aluminum MacBook 2.0GHz Collector's Edition
Windows Box: 2.26G P4, 1GiB RAM, 320GB SATA + 80GB PATA HDD, Nvidia FX5200
AOC Fovi F22
iPod Touch 16GiB, HTC Gene, Moto W230, Sansa Express
04-11-2008, 05:00 AM
AMD & ATI FANBOY
Re: Very Strange!
the board has 2 slots ,, the board is little old model ,,
Proc:AMD 2X 5200+
Any help?
hey i found that the board cannot support the BRAND "SIMTRONICS" RAM ,, using simtronics gives u problem like this
Reason: Automerged Doublepost
04-11-2008, 07:29 AM
Re: Very Strange!
Am using both Trascend.
www.harivarrier.com
04-11-2008, 07:53 AM
Re: Very Strange!
Try using both of the rams on other mobo/pc.
04-11-2008, 10:35 AM
AMD & ATI FANBOY
Re: Very Strange!
this is undefinable ,, cant say u exact reason buddy may be check ur mobo and also RAM with the dealer
04-11-2008, 09:11 PM
Re: Very Strange!
There seems to be a bios problem(Even after updating) wherein it doesnot support two RAM
www.harivarrier.com
04-11-2008, 09:18 PM
AMD & ATI FANBOY
Re: Very Strange!
dude ,, in bios its showing as DUAL CHANNEL or not???
05-11-2008, 12:17 AM
Re: Very Strange!
It shows as dual chanell. But when I searched in google many ppl found a similar problem and most of them opted for a 1x2GB RAm rather than a dual channel 2x1GB RAM
I am going to do the same. The computerwala said he will change the rams and get me a sibgle 2GB RAM STICK.
Thanx for all the help guys, specially to ultimategpu.
www.harivarrier.com
05-11-2008, 12:47 AM
AMD & ATI FANBOY
Re: Very Strange!
its kk ,,, u r welcome
05-11-2008, 07:14 AM
Re: Very Strange!
This way you have solved the problem buy what will happen when you add another 2gb module in it? Try doing this.
And go to the root of problem so that in future you don't have to face this again.
05-11-2008, 05:20 PM
Re: Very Strange!
^ +1. Instead of changing RAM; if the dealer allows; try changing the motherboard.
AOC Fovi F22
