Old 03-11-2008, 04:49 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Drool!...Vista
*GandaBerunda*'s Avatar
Exclamation BSNL modem 'forgets' port forwarding after it is restarted
I'm having a ut-300r2u BSNL modem. ( 2.5 years old)
After referring to portforward.com ,i set up port forwarding for utorrent.
When i set up port forwarding , the network status icon in utorrent turns green. But however , when i restart my modem , it seems to lose its settings and the network status icon turns yellow again.
The added forwarding disappears from the modem's virtual servers page.
If i set it up again , then it the utorrent status again becomes green.
Can anyone help me out?
Is it because of a firmware mistake? I could not find any firmware update for download.
My current firmware version is R100B02.7AS.B
Visit my blog http:\\geekgarbage.blogspot.com, but don't click on the ads :)
*GandaBerunda* is offline
Old 03-11-2008, 04:58 PM   #2 (permalink)
Default Re: BSNL modem 'forgets' port forwarding after it is restarted
could it be using a cell battery to save settings and that battery could have run out?
dont know whether modem use it to save the settings..
but since it save your other settings then it may be ruled out
reset the modem and tried it to see what happen
http://www.calcutta.bsnl.co.in/datao.../pppoe04a.html
realdan is offline
Old 03-11-2008, 05:03 PM   #3 (permalink)
Drool!...Vista
and yeah..i forgot to add...i've reset my modem once...
Old 04-11-2008, 01:18 PM   #4 (permalink)
paroh's Avatar
In misc there is a option of save and reboot
paroh is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/101224-bsnl-modem-forgets-port-forwarding-after-restarted.html
Thread Port forwarding after update 5 | community.smoothwall.org | BoardReader This thread Refback 01-08-2010 02:09 PM
Tutorial: Port Forwarding in ZTE ZXDSL 831AII Modem 100% working! jal_desai Tutorials 13 13-06-2009 05:12 PM
Port Forwarding in BSNL's Seimens C2110 Modem ? Krazy Bluez Networking 2 18-10-2008 05:03 PM
Port forwarding bsnl router Arsenal_Gunners Networking 8 17-05-2008 09:02 AM
Port Forwarding Failing BSNL Dataone jetru Software Q&A 1 11-06-2006 04:53 PM
