Old 03-11-2008, 11:47 AM   #1 (permalink)
Leonidus06's Avatar
Default How to connect a TV tuner card with a laptop
Hi Friends,
Can any1 please advise me how to connect a External TV Tuner Card with Laptop ?
I was wondering if its possible i could connect my modded PS2 with it, and play.
Please advise me guys.
Leonidus06 is offline
Old 03-11-2008, 12:59 PM   #2 (permalink)
Designer Here
techking_dinesh's Avatar
Default Re: How to connect a TV tuner card with a laptop
which tv tuner card u hav ??
techking_dinesh is offline
Old 03-11-2008, 03:07 PM   #3 (permalink)
Leonidus06's Avatar
I dont have one but would like to buy one, can you suggest a suitable one, i have a compaq presario laptop, but it does not work...i mean i dunno what the problem is with it. I vl get it repaired soon, but in the meanwhile i wish to use its LCD screen only will be be feasible to connect it externally ? If u know how please advise me.
Old 03-11-2008, 05:07 PM   #4 (permalink)
i doubt you can do it the way you wanted it to be done for you
realdan is offline
How can I connect my DishTV to my PC (tv tuner card)? Rockstar11 Hardware Q&A 15 08-01-2009 10:00 AM
How to Connect DTH to TV Tuner Card? anandsagi Hardware Q&A 1 28-10-2008 03:44 PM
Need Tv Tuner card for Laptop catchjaga Hardware Q&A 4 16-08-2006 12:12 PM
