Old 01-11-2008, 08:18 PM   #1 (permalink)
anubisX's Avatar
Default LED Flickering !!!
I bought this Thermaltake StrikeMX VI6001 cabinet yesterday and today the LEDs on the 230mm fan has started flickering, it's happening with all Red, Blue, Green. Is it a LED issue or there is a problem with the power cord ??? Or it's a power issue, do I need to upgrade my PSU ??? My current config is : Abit IP35-E | Intel E8400 | Corsair 6400 4x 1GB | Seagate 1TB | Radeon HD3650 512MB | Samsung DVD-RW | 230mm fan is also consuming power.......
anubisX is offline
Old 01-11-2008, 08:30 PM   #2 (permalink)
PowerDaemon
Musicmaker23's Avatar
Default Re: LED Flickering !!!
actually it may be a bit of all that u mentioned -
this is what u need to do in order:
1. Check your bios - make whatever necessary changes
2. Connections may be faulty in all probability only if even the fan is malfunctioning
3. PSU's going berserk [U havn't mentioned which smps u're using!!] - check it out [with your system, i hope u havn't taken the cabinet + smps combo & rather fit in your own]
4. Pray to God, you've bought it with a warranty!!
btw, nice choice of a cabinet!!
HP dv9222tx+
MeanMachine: [Intel Core2Quad Q9300 2.5Ghz] [Asus P5-KVM] [4GB RAM 800Mhz] [nVidia XFX GeForce 8600 512 MB] [500GB WD SATA] [Sony 20x ODD] [Neotech 600W SMPS][Vista Ultimate+Office07]
Last edited by Musicmaker23; 01-11-2008 at 08:33 PM. Reason: Automerged Doublepost
Musicmaker23 is offline
Old 02-11-2008, 09:03 AM   #3 (permalink)
anubisX's Avatar
It's Point Of View 500 Watt. Now, I know what the problem is. No sufficient power. The 230mm fan is consuming a lot of power, so I had to plug-off the DVD-RW to stop the flickering of the LEDs.
anubisX is offline
LCD flickering Plasma_Snake Hardware Q&A 7 26-07-2008 10:32 AM
Flickering ! ! ! ax3 QnA (read only) 3 10-01-2006 04:19 PM
My PC screen is flickering sush5 QnA (read only) 6 20-09-2005 10:16 AM
Monitor Flickering!!! Biplav QnA (read only) 8 14-09-2005 02:49 PM
flickering firefox GunshotSilence Internet & WWW 7 08-09-2005 05:39 PM
- by bhaskar
