Old 31-10-2008, 06:27 PM   #1 (permalink)
sharma_atul85's Avatar
Smile monitor beep
hello friends when I startup my system then when my monitor (LG 300E) makes a strong beep type of noise..what can be the problem???although it was not the same few months back.
sharma_atul85 is offline
Old 05-11-2008, 12:23 PM   #2 (permalink)
Norms Buster
Default Re: monitor beep
Are you sure that the beep is coming from the monitor ?
I've never heard about monitors making any beeps...
VexByte is offline
Old 05-11-2008, 12:53 PM   #3 (permalink)
15.0 GHz
VarDOS's Avatar
i too never herd any monitor making beeps...
VarDOS is offline
Old 05-11-2008, 01:02 PM   #4 (permalink)
AMD & ATI FANBOY
ultimategpu's Avatar
its normal ,, do u find any disturbances in the pictures???? dont worry
GAMING RIG=>C2DE8500 | ASUS P5Q PRO |3GB DDR 800 |VIEWSONIC VX1932WM|CM 600 WATTS |PALIT 4850
PC RIG=>AMD PHENOM X4 9550 | ASUS MOBO |2GB DDR 667 |CORSAIR 450 WATTS |17"TFT LG |2 TB SEAGATE
ultimategpu is offline
Old 06-11-2008, 11:56 AM   #5 (permalink)
mainly it happens only while booting .it makes a noise something what comes out while degaussing..
Continious Beep at start rameeze Hardware Q&A 3 15-04-2008 10:49 AM
Beep......... BBThumbHealer QnA (read only) 3 18-02-2007 08:10 PM
Meaning of the BEEP Sounds in PC techno_junkie Hardware Q&A 2 27-11-2005 07:31 PM
computer not starting no beep AMITAGARWAL02 QnA (read only) 18 26-08-2005 12:33 AM
beep beep hang!! hearthacker QnA (read only) 2 27-12-2004 09:41 AM
- by bhaskar
