Old 31-10-2008, 12:57 PM   #1 (permalink)
Default Need Info About This DVD-Writer...
Hi Everyone,
I'm planning to buy a DVD Writer. I'm looking at Sony DRU-245S. Can anyone please give me some feedback on this model. I know its a SATA based drive. Can anyone please suggest a good IDE alternative for this as well. Thanks!
hell_storm2006 is offline
Old 31-10-2008, 02:37 PM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: Need Info About This DVD-Writer...
Googling produces no results. Can you give us a page link?
dheeraj_kumar is offline
Old 31-10-2008, 02:40 PM   #3 (permalink)
Fullbring
Zangetsu's Avatar
In the world of SATA y u want a IDE writer...
Zangetsu is offline
Old 31-10-2008, 04:41 PM   #4 (permalink)
I have an old PC for which I want to buy a DVD Writer as well... So looking for and IDE Writer also.
I need the SATA one for my new PC.
@ dheeraj_kumar :
One link is....
http://www.videohelp.com/dvdwriters/sony-dru-845s/2413
Sorry I made a mistake in the first post... its 845S... not 245S ....
My mishtake!!!!
Last edited by hell_storm2006; 31-10-2008 at 04:45 PM. Reason: Automerged Doublepost
Old 31-10-2008, 04:46 PM   #5 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Whether it is sata or pata it doesn't make any difference except that sata has shorter cables (for writers). Writer will never use the bandwidth provided by pata.
Get Sony/samsung dvd burner, which ever costs less.
desiibond is offline
Old 31-10-2008, 08:27 PM   #6 (permalink)
Samsung has a pretty bad name in optical drives. Though they may have improved lately. Why dont you consider LiteOn? Just bought one myself.
As for SATA interface, I belive you can get an add-on card which will give you SATA port(s) on your old comp. But I guess it will add to your cost. So thats probably worthwhile only if you plan to shift the drive to a newer mobo.
Raccoon is offline
Old 01-11-2008, 05:01 PM   #7 (permalink)
This is just a rebranded samsung writer... search for more info at cdfreaks.com forum, they test all sorts of drives.
Old 01-11-2008, 05:08 PM   #8 (permalink)
M3TAL H3AD M3
skippednote's Avatar
Better get lite on or asus dvd writer for best performance. Other brands like lg samsung sony are also worth buy....!
I spit Rainbows.
skippednote is offline
Old 02-11-2008, 03:46 AM   #9 (permalink)
Which drive is a rebranded Samsung? Surely not LiteOn??
Raccoon is offline
Old 02-11-2008, 09:15 AM   #10 (permalink)
anubisX's Avatar
Get Lite-On DVD-RW, Sony is not that good. You can get Samsung too but Lite-On is the best, no serious complains so far. IDE and SATA, both are available.
anubisX is offline
Old 02-11-2008, 01:15 PM   #11 (permalink)
@Raccoon
The drive OP wants to buy - Sony DRU-845S is a rebranded samsung.
Old 02-11-2008, 03:38 PM   #12 (permalink)
Ohh ok! Not a good buy then... I guess...
Raccoon is offline
DVD writer damn slow..I got IMATION dvd writer.. roonie Hardware Q&A 9 09-01-2008 08:05 PM
got a new dvd writer Samsung Super WriteMaster 18x DVD Writer xbonez Hardware Q&A 7 14-08-2007 02:10 PM
Sony dvd writer info ??? dinesh_mettur QnA (read only) 5 01-01-2007 07:41 PM
Lg Dual Layer Dvd Writer??? Info Plz.. dinesh_mettur QnA (read only) 11 18-11-2006 07:03 AM
- by bhaskar
